| recelect |
08-08-2010 02:27 PM |
Re: Crazy Gauges
Originally Posted by injected1
(Post 24742)
Ok, taking a break to find a 5/16th" wrench and cool off. lol I have determined that this problem is isolated to the gauges and when it occurs it drops the voltage to everything else in the front of the boat. I unplugged the harness that only feeds the gauges and all other voltages are normal. I cut the power and isolated it from the rest of the boat. I then hooked a hot wire to the hot and poof. They were wacky just like normal, however the voltages were normal everywhere else. I went through and clipped the sender wires one by one and am hooking them up one by one. However, I noticed with the sender clipped, the oil pressure gauge still pegs. I am looking for a wrench to unhook the common power to it to see if it is the problem. The common ground on all the gauges just runs the lights in the gauge, but I clipped it just to be safe. They still do the same thing without it. This has been such a pain. I've been all over this thing trying to fix this.. Phew!!
I would still make sure you have a good ground.The common ground runs the lights yes, but also the gauge. You might be looking at the hot wire for the lights. The grounds should be white or black. Most likely white. You can get low voltage readings if the ground is bad, and this can cause the guages to spike. Try running a jumper from the ground of the battery to the grounding block under the dash and see if this fixes it. The only way you would drop that much in voltage is if you had a direct short that is unfused (which would cause a fire) had a large power draw from a motor (and the battery is weak, which it doesn't sound like) or if you have a bad ground.
Also the lights on the guages should not be on unless you have your navigation lights on. If they are, I am positve you have a ground issue, or if you have had to replace any guages, maybe they are hooked up backwards. The only other thing I would look at/try is to see if your trim sending guage is causing problems. The trim sending unit wires often corrode and short, which could cause some issues, but I still don't think that is what your problem is.
If you're in Colorado, you can always bring it to my shop. I specialize in these issues.
