Facet in Cuddy - water source and how do i prime
I have a 1994 Davanti 235 with a tap in the cuddy that is the "pump" style and I would like to know where this is hooked up to? My understanding is that it draws the water from the lake but i cannot find where that it and I have no idea on how to prime this to get it to work.
Re: Facet in Cuddy - water source and how do i prime
Not positive, however it should be connected to you freshwater holding tank.
Great! i have looked and cannot find a fresh water tank...are you familar with this boat and know where i could find it? I do not have a fresh water intake anywhere on the boat and i cannot get to where this tap is located so i don't know where it draws the water from. The owners manual is of no help...
Do you have a refrigerator? If so the tank is behind it.
my boat uses one of these, and yours probably does too if it doesn't have a holding tank...
http://content.westmarine.com/images...umb/232678.jpg RELIANCEJerryjug at WestMarineNew |
If you have a holding tank your filler is above the rubrail amidships on the starboard side.
Posting at the same time aargg. Mine has a 14 gal aluminum tank behind the fridge...
I have just joined the club, I have a 1996 cuddy22, does anyone know where the water tank is and how to get to it, The boat has a filler on the side that seems to head towards the bow.
| All times are GMT. The time now is 10:47 AM. |
