-   -   Trim Switch problems (http://www.mariahownersclub.com/forum/general-maintenance/3997-trim-switch-problems.html)
chriskeller82 05-03-2010 01:51 AM
I have a 92 Z2000. The up switch on my trim tab no longer works. The down and trailer modes work but no up....Any suggestions on what to troubleshoot and if I can't get it to work again where I can go to order a new one.
WetWilly 05-03-2010 06:35 AM
Re: Trim Switch problems
Hi chriskeller82, I had the same issue many years ago, click here and read what I wrote in this thread and yes, most parts should be available.
Hope it helps,
WetWuilly
P.S. when you find your problem, come back and let us know what it was, Thanks :wink_thumbup:
The Boat 05-09-2010 03:23 PM
I had the same problem last year but mine was not corrosion it was a scew that had broken and was very easily fixed...sort of. I had the mechanic at the local marina look at it and they could not figure out what was wrong and then I took the boat somewhere else where they found the problem. It was on the outside of the drive.
