-   -   Hull Cleaning (http://www.mariahownersclub.com/forum/general-maintenance/3359-hull-cleaning.html)
andyc 09-21-2009 07:49 PM
Hull Cleaning
Hi as the boating season is about to end in Scotland I am looking for any tips on how to get the water marks off the hull of my boat,she has been sitting in fresh water since May and has a fair bit of algie on her I have managed to get some of the heavy grime off her while she is in the water but she looks a bit yellow under the waterline.Any advice greatfully recieved.
Andyc
WetWilly 09-22-2009 05:05 AM
Re: Hull Cleaning
Hi Andyc,
The forum has a pretty good "search" function (In the Blue Bar near the top of the page), you can find most of what has been already discussed on all the sub-forums. Try the "Advanced Search" to zero in on your topic (click here).
In the mean time, check out this thread (click here), it covers several solutions to hull cleaning.
Good luck,
John Frazee 09-22-2009 04:24 PM
Re: Hull Cleaning
If you have a Walmart near, go there and get Hull Cleaner. It is in a blue bottle and cost under $10.00. It will cover your boat twice. You spray on and rinse off. It takes all the stains completely off instantly! Great stuff. If you don't have a Walmart go to your boating supply store and ask for hull cleaner. Trying to scrape the stain off will do damage before it cleans off.
andyc 09-23-2009 11:06 AM
Re: Hull Cleaning
Hi John Frazee,Thanks for the advice,we dont have Walmart here in Scotland,they call themself ASDA here but they only supply household goods:shakehead:, I have read earlier threads and the one that comes up is Starbrite, I have some on order:wink_thumbup: Hopefully I will have it for the weekend and I will let you know how it works.
Andyc
andyc 09-28-2009 06:06 PM
Re: Hull Cleaning
Just a wee update Starbrite hull cleaner does exactly what it says on the tin.
Wipe it on with a sponge or spray(I used a spray bottle) leave for 2 mins and wash off with plenty of water all the brown marks amd water lines gone SUPERB.
I would recommend that you do not do this in a garage as it is quite strong and you need plenty of air about you...
Andyc
BayLaker 10-01-2009 09:38 PM
fuel/oil scumline on hull
I use starbrite a few times a season to very easily remove algae/green/brown hull staining. however, its the end of hte season and is a faint visible black line, presumably from oil/fuel exhaust on the surface around the dock at times.
starbrite doesnt affect this. anyone know of something that works well to remove this fuel stain??
