Starter Clicking won't start??
Thanks in advance for any feedback!
I think it may be a fuse issue but that is only a guess! I was pulling into the dock & stopped to wait for some others to get situated when I went to crank the boat I think I heard a pop & then the starter wouldnt engage the engine & all I could hear was a click click click? Anyone ever have this issue & know the fix? thanks again!! |
Re: Starter Clicking won't start??
The *click* you hear, assuming it's coming from the engine space, would almost certainly be the starter relay pulling in when you turn the key. The fact that the starter motor's not turning can mean one of several things: Poor connection (the big, fat cables), bad starter, bad starter motor, possibly bad battery. This is easy to trouble-shoot with a multi-meter. Here's how I'd do it: I'd set the meter to measure 12VDC and measure between the terminal where the big red cable from the battery connects, and ground. Then, being very careful to keep my limbs and loose clothing out of the way of potentially moving engine bits, I'd have somebody turn the key and see if the voltage stayed up. If it didn't, I'd know it was the connection/cabling between there and battery or, less likely, but possible, a bad battery. If it did, I'd then move the test point to the starter motor side of the starter relay and again ask to have the key turned. If I saw there the same voltage I saw on the battery side of the relay, I'd know it was either the cable between there and the starter motor or the starter motor itself. Jim |
| All times are GMT. The time now is 12:44 PM. |
