Cupholder Drains
General Maintenance
Old 08-30-2007, 03:28 PM   #1
Straad's Avatar
Straad is currently offline
My Model: Barchetta 182
My Engine: 4.3 Merc
Gallery Images: 8
Send Straad:
Default Cupholder Drains
i just wish mine drained, they are allways FULL of water
....i have 4 kids, not a dry place on my boat
Straad
1995 Barchetta 182, 4.3L
Southern Mid-Michigan
  • Old 08-30-2007, 05:21 PM   #2
    94 Talari's Avatar
    94 Talari is currently offline
    My Model: 180 Talari
    My Engine: 4.3L LX
    Gallery Images: 2
    Send 94 Talari:
    That's an easy one, just drill a hole in the bottom of each one.
    1994 Mariah Talari 180 4.3 LX
    Old 08-30-2007, 08:50 PM   #3
    Straad's Avatar
    My Engine: 4.3 Merc
    Gallery Images: 8
    Send Straad:
    but then where does the water go?
    i thought about that but then figured with my luck it would end up leaking directly onto the fuse box or soemthing
    Straad
    Old 08-30-2007, 08:56 PM   #4
    I read once a guy on one of those "other" forums, where a guy used aquarium air tubing to route all the holes in his cupholders to the bilge. If you've got the time and patience for it, I'd recommend that. Might not be a bad idea for an off-season project? In the meantime, I just use paper towels!
    Old 08-31-2007, 01:39 AM   #5
    KSP181's Avatar
    KSP181 is currently offline
    My Model: 1994 Barchetta 182, 4.3L alpha 1
    Send KSP181:
    Straad, I'm with you. I have 3 kids and water is in the cupholders all the time. When you put a drink in the cup holder and water is pushed out over the top, it just makes you think WHY?
    1994 Barchetta 182 - 4.3L
    Vic
    Old 08-31-2007, 01:45 AM   #6
    i did just that with mine. I bought some new cup holders that had a drain hole c/w a nipple at the bottom & attached some aquarium airhose so that the water would drain into the bilge. Took a little time to route the hose but eliminated the problem completely.
    Old 08-31-2007, 05:16 PM   #7
    180diablo's Avatar
    My Model: 1993 Diablo 180
    Gallery Images: 30
    Send 180diablo:
    I had a resident spider living in my starboard rear cupholder...
    I have a cover leak coming in from somewhere, because I know when I open up the boat there is some water in the holders as well as the side rails where they sit. Not a big deal however, but .. it is there.
    ~ Ryan
    Owner of the 3.0L Powerhouse!
    Old 09-04-2007, 03:14 PM   #8
    94 Talari's Avatar
    My Engine: 4.3L LX
    Gallery Images: 2
    Send 94 Talari:
    After closer examination this weekend, it looks like the previous owner drilled a hole in the bottom of each of the 4 cupholders in the main part of the boat, but left the 2 up front in the bow alone.
    Old 09-06-2007, 02:53 AM   #9
    Boatcrazy posted this link for Stainless steel cupholders c/w a drain hole in the Introductions forum under the 99Z302 thread;
    https://www.surplusunlimited.com/Mer...tegor y_Code=
    Old 09-07-2007, 05:23 PM   #10
    bdbyrnes's Avatar
    bdbyrnes is currently offline
    My Model: Talari z240
    My Engine: 7.4L V8 - Bravo III
    Gallery Images: 41
    Send bdbyrnes:
    Excellent - thanks!
    There are 367 users
