oil filter and gas filter
General Maintenance
Old 02-17-2009, 01:45 AM   #1
wssb11 is currently offline
My Model: 1996 Mariah Shabah 4.3 Mercruiser Alpha one
Send wssb11:
Default oil filter and gas filter
dumb thread here..........i decided that i was going to change the oil and filter this week end and at the same time i decided i might as well change the gas filter. Drained the oil and went to take the oil filter off but its on so tight i cant even get it to budge. lol i put all i have into the oil filter and it wont move at all!!! so i decided to change the fuel filter same problem. Righty tighty lefty loosey right? lol they wont move!! I just bought this boat the fall of last year so i didnt change the oil last but im definetaly cussing the person that did!!! anyone have an idea of how to get them off there only suppose to be hand tighten right? I dont wanna break anything cause im pretty good at that anyone have any tips. thanks
  • Old 02-17-2009, 01:57 AM   #2
    Default Re: oil filter and gas filter
    Are ya sure you're turning them the right way?
    I've seen some mechanics take a long heavy duty screwdriver and hammer it right thru the oil filter and use the screwdriver to remove the oil filter. Kinda messy though.....
    Old 02-17-2009, 01:32 PM   #3
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    Are you using a filter wrench, or just your hands? Try some penetrating oil around the gasket, then a pipe to extend the wrench handle and give some leverage. Be careful on the fuel filter - make sure you don't break the mount.
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 02-17-2009, 02:04 PM   #4
    blockp's Avatar
    blockp is currently offline
    My Model: 99 Jubilee 214
    Gallery Images: 8
    Send blockp:
    It sounds like the installer didn't wet the gasket when they installed the filter. Usually the problem is that the gasket is stuck to the filter mount. Put on some pressure with the filter wrench, then tap around the top of the filter with a hammer (lightly!).
    I've successfully used the screwdriver through the filter method. I've also used a heavy duty filter wrench with a chain around the filter. With enough pressure you will completely collapse the filter, but it will eventually come off. Again, some tapping with pressure will usually help it break free.
    If all of that fails, the worst one I ever took off... the filter body completely collapsed and broke free from the threaded part of the filter. I scraped the crusty oring from the filter mount, then using a small pipe wrench, I took the threaded part of the filter off the mount.
    Like someone else said... messy, but it works.
    Fuel filter location on a 2000 7.4 MPI? Jeff Barnett Mercury MerCruiser 6 11-20-2007 09:15 PM
    There are 301 users
