182 barchetta nav switch
General Maintenance
Old 04-01-2024, 01:56 PM   #1
Twiesen is currently offline
My Model: 182 barchetta
My Engine: 4.3 alpha one
Send Twiesen:
Default 182 barchetta nav switch
Good morning,
I have a 1996 barchetta 182 and noticed the nav lights are not working. Investigating, I found the rotary switch had failed just to the right of the ignition key. Does anyone have the wiring diagram for this as well as a lead on where I can get a new switch? I would like to keep the original design. I appreciate your help.
  • Old 04-01-2024, 02:06 PM   #2
    GregT is currently offline
    My Model: Z275ST
    Gallery Images: 7
    Send GregT:
    Default Re: 182 barchetta nav switch
    That rotary switch is for the dimmer on the panel lights. If it is broken, may be able to find a old replacement on Ebay. For new switches, I've used both New Wire Marine and OTRATTW.net for switches and covers. If all the nav lights are out, make sure you check the fuses/circuit breakers also.
    Old 04-01-2024, 04:13 PM   #3
    Send Twiesen:
    I’m not familiar with how the wiring is supposed to be, but it’s a 3 position rotary switch. Assuming on/off/on. The nav lights were spliced together and put into this switch. Only wires attached besides the power and ground. It has an indicator light on it. Both nav lights function. I’ll have to see if I can post a picture of the switch and the console. I appreciate the help, I’ll check out those two places you sent.
    Old 04-01-2024, 04:29 PM   #4
    My Model: Z275ST
    Gallery Images: 7
    Send GregT:
    Not totally sure if this diagram covers your model, but may help a little for wiring.
    Old 04-01-2024, 05:14 PM   #5
    Send Twiesen:
    https://www.westmarine.com/sierra-ro...SABEgLMDvD_BwE
    Here is the switch, or atleast a version of it. Seem correct?
    Old 04-01-2024, 05:24 PM   #6
    My Model: Z275ST
    Gallery Images: 7
    Send GregT:
    My boat doesn't have this model switch so I'm no help identifying if it is correct or not. Can you find any part number on your existing switch to google?
    Old 04-02-2024, 01:12 PM   #7
    Send Twiesen:
    I found a switch that I can use. I don’t know how the original wiring was done as the last owner did some weird splicing to make it work. I’ll wire it so one side of the switch will turn on the anchor light and the other side of the switch will run both blades turning on the anchor light and nav lights. I have a rocker switch labeled pnl lights which turns on my dash lights, so I’ll either jump from there to run the indicator lights for the rotary switch or I’ll jump off the single side of the rotary switch so they’ll turn on every time I use the nav lights. Thanks again for the help. The parts numbers menu that y’all have was what I used to find that type of switch.
    Old 04-02-2024, 03:09 PM   #8
    My Model: Z275ST
    Gallery Images: 7
    Send GregT:
    sounds like you have a plan - hope it all works out. The wiring diagrams Mariah used were bare basic line drawings with wire colors. not sure how much that would have helped.
    99 mariah 20ft switch type kill switch esc0029 Original Mariah Talk 0 05-14-2022 02:35 AM
    Barchetta? chuse927 Chit Chat/Off-Topic 2 02-14-2017 06:35 PM
    95 Barchetta 182 or 192? jasonbormann Boating 101 1 04-06-2015 08:04 PM
    94 Barchetta switch problem biker Original Mariah Talk 6 05-15-2014 01:36 PM
    94 182 barchetta brett weber Introductions 6 02-20-2008 05:38 PM
    Total Members: 18,990
    Total Threads: 13,324
    There are 387 users
