-   -   no dash lights, no bow or stern lights (http://www.mariahownersclub.com/forum/general-maintenance/12435-no-dash-lights-no-bow-stern-lights.html)
JR1996mariah 07-28-2019 10:33 AM
i have a 1996 mariah shabah 180. i have a single switch, two clicks to the right. how do i check the switch for continuity? if i apply power at the bow light i have dash/bow/sterm lights. does the switch regulate ground? or does the switch regulate voltage? looking to find out why i don't have voltage to the lights.
JR1996mariah 07-28-2019 07:35 PM
Re: no dash lights, no bow or stern lights
does anyone know if the light switch is on/off/on or off/on/on, 2 position or 3 position
JR1996mariah 07-28-2019 09:05 PM
got it, voltage supply to switch, on/off/on, dim/off/bright, if you are having problems with lighting, check for power to the switch, check switch wiring, my switch was wired wrong
