Magic Spark Plug Wrench
General Maintenance
Old 07-14-2017, 04:10 PM   #1
Scottie1961's Avatar
Scottie1961 is currently offline
Status: Gold Contributor
My Model: Z202 Shabah
My Engine: 5.7L Alpha One
Send Scottie1961:
Default Magic Spark Plug Wrench
OK, it's not really magic but boy I found a spark plug socket that seems to work really well on my 5.7 Mercruiser. I've got several different tools including a T-handle socket wrench and assorted sockets. They all seem to have the same issue with binding against the bottom of the manifold. I worked a couple of plugs out using assorted tools and went to Oreilly's to get new plugs. Just by chance I looked in the tool section and saw a 5/8" (they have other sizes) plug socket with built in knuckle joint. I thought what the heck I'll give it a shot.
This thing really worked like magic. I got the other two plugs out quickly and then changed the four on the other side in about 5 minutes. I started all the plugs with a rubber hose going back in but used the new socket to snug them up. The problem with all the other sockets I have is the five sided wrench fitting at the upper end. If you've used them you know what I'm talking about. The points seem to bind up against the manifold and then you're stuck. The decision is always should I keep turning or stop and back off.
This new socket doesn't have those edges and it's a little shorter than the other sockets I have. No guarantees but if you're dreading changing out your plugs but need to change them you might give this little guy a shot. Good luck!!!!
PowerTorque Tools - Spark Plug Socket
Part # GM6225 Line: PTT
1995 Mariah Z202 Shabah
5.7 Alpha One Gen II
Thank you Scottie1961 for this useful post!
Firestone (07-14-2017)
  • Old 07-14-2017, 04:44 PM   #2
    My Model: Z202
    Send Firestone:
    Default Re: Magic Spark Plug Wrench
    Dang that does look very useful!
    John
    Old 07-14-2017, 05:10 PM   #3
    pllevine's Avatar
    pllevine is currently offline
    My Model: 202 Shabah
    My Engine: 5.0L Alpha
    Send pllevine:
    Did you use Anti-Seize compound on the threads and a torque wrench to tighten them to the proper amount?
    Phil Levine
    1998 202 Shabah
    Old 07-14-2017, 07:39 PM   #4
    Send Scottie1961:
    No, had a bad experience with anti-seize on spark plugs. I do however use a beam type torque wrench just to get it close.
    Old 07-14-2017, 07:41 PM   #5
    pllevine's Avatar
    Send pllevine:
    What sort of bad experience could you have?
    Phil Levine
    1998 202 Shabah
    Old 07-14-2017, 07:49 PM   #6
    Send Scottie1961:
    4.6 Ford Triton
    Torqued all plugs to specs and within two weeks two plugs worked their way out enough that compression was affected. I know many people have used anti-seize without issues but I change them often enough that it's really not an issue for me. I just like to seize the moment I guess
    Old 07-14-2017, 07:52 PM   #7
    pllevine's Avatar
    Send pllevine:
    4.6 Ford Triton
    You're talking to a guy that owns a 2005 Ford F-150 with the 3V Triton engine. Plugs went in at the factory with no anti-seize. The plugs are two pieces crimped together and they break in half when you pull them out...
    Phil Levine
    1998 202 Shabah
    Old 07-14-2017, 08:03 PM   #8
    Send Scottie1961:
    Oh yeah, those goofy long spark plugs are a real pain. The 4.6 had a problem with the insulator breaking during removal, but that was on the outside thankfully! I've heard horror stories of guys trying to get the bottom half of the plug out of the head on the 5.4.
    Old 07-14-2017, 08:05 PM   #9
    My Model: Z202
    Send Firestone:
    Yeah has 3 break in my Lincoln Navigator. $600 to change the plugs. Now have one piece plugs
    John
    Old 07-14-2017, 08:13 PM   #10
    Send Scottie1961:
    It seemed like a good idea at the time to some engineer in the R&D department.
    7.4 Mpi spark plug gap 99 Mariah 258 General Maintenance 3 08-17-2015 10:52 PM
    Spark plug wires Juskol18 Mercury MerCruiser 7 04-04-2014 11:22 PM
    spark plug help Juskol18 General Maintenance 15 04-12-2013 03:35 AM
    spark plug help again aquaknot Mercury MerCruiser 4 09-12-2010 12:12 PM
    Spark plug MMarko Original Mariah Talk 1 03-16-2009 02:13 PM
    Total Members: 18,990
    Total Threads: 13,324
    There are 386 users
