Trim tabs make sound but do nothing.
General Maintenance
Old 07-10-2017, 04:34 AM   #21
1996 Mariah Z252 is currently offline
My Model: Z255 Shabah
Send 1996 Mariah Z252:
Default Re: Trim tabs make sound but do nothing.
Originally Posted by tbrookens View Post
I'd tackle on thing at a time. Get the pump working again, and then work on the switch.
The pump works, fine but I'm trying to figure out if the hydraulic is bad or if it's just a bad connection.
  • Old 07-10-2017, 10:07 AM   #22
    tbrookens's Avatar
    tbrookens is currently offline
    My Model: Shabah Z252
    My Engine: 454 Mag, Bravo 3
    Gallery Images: 2
    Send tbrookens:
    If the pump is working fine, then you should see movement on at least one of your tabs. If the fluid isn't leaking out, it has to be going somewhere when you build up pressure. Air compresses, fluid doesn't. I'm betting you have to bleed the air out of the system.
    Tracy Brookens
    Old 07-10-2017, 10:42 AM   #23
    Tabman is currently offline
    Send Tabman:
    Counter Intuitively the system requires more power to bring the Tabs up than it does to put them down. I would suggest you check and clean all the electrical connections. Pay particular attention to both ends of the ground wire.
    Tom
    Bennett Marine
    Old 07-10-2017, 03:24 PM   #24
    I do see movement in one of my tabs.
    Old 07-10-2017, 05:21 PM   #25
    tbrookens's Avatar
    Gallery Images: 2
    Send tbrookens:
    Full movement, or just a little bit?
    Tracy Brookens
    Old 07-10-2017, 05:29 PM   #26
    Full movement. Only works going down though. The wiring is fine. I just checked it.
    Old 07-10-2017, 05:41 PM   #27
    I think that I need to replace both hydraulics. Anyone else agree?
    Old 07-10-2017, 05:45 PM   #28
    tbrookens's Avatar
    Gallery Images: 2
    Send tbrookens:
    I don't agree, but I'm not there troubleshooting the issue. By "hydraulics" I assume you are talking about the actuators? Or are you referring to the entire system? Why would the actuators cause the switch to not work in one direction? There is no electrical power to the actuators.
    Tracy Brookens
    Old 07-10-2017, 05:47 PM   #29
    Yes I mean the actuators.
    Old 07-10-2017, 05:48 PM   #30
    Also if I touch the wires together manually it does nothing.
    Wanted: trim tabs eagleman201 Mariah Parts For Sale & Wanted 2 12-13-2015 03:39 AM
    Trim Tabs edward cossey Projects 2 07-15-2012 06:49 PM
    Key wont make a sound in the ignition after being winterized ndercole Mercury MerCruiser 2 05-30-2012 02:54 AM
    trim tabs ?????????? boat man2 Original Mariah Talk 6 07-07-2009 12:07 PM
    There are 436 users
