Trim tabs make sound but do nothing.
General Maintenance
Old 07-09-2017, 10:19 PM   #11
TCJ95Z-235 is currently offline
My Model: Z235 Davanti
My Engine: 7.4L Bravo1 Corsa
Send TCJ95Z-235:
Default Re: Trim tabs make sound but do nothing.
Sorry it wasn't as simple as low fluid level.
Insta Trim (Insta-Trim.com) manufactures the system for Boat Leveler Co. now. You can buy directly but the prices seam a little higher than popular boat part suppliers.
Viewed and listened to the video you posted on you tube.
Is your battery in good condition and fully charged ? Low voltage can cause the motor to run but the valves may not open.
After you ran the pump through several cycles did the fluid level in the reservoir change ?
Google search "insta trim boat leveler trim tab troubleshooting" on the first page is a post "Trim tab issues - The Hull Truth"
contained in there is a wire chart by color and function. There are also several tests listed that will get you to the root of your problem.
Hope this helps.
  • Old 07-09-2017, 11:30 PM   #12
    1996 Mariah Z252 is currently offline
    My Model: Z255 Shabah
    Send 1996 Mariah Z252:
    Hope this helps.
    Yes I just replaced both of the batteries with 2 deep cycle marine batteries 2 weeks ago.
    Old 07-09-2017, 11:40 PM   #13
    Also while I ran it through several cycles the fluid level didn't change. It might have a little bit, but I couldn't tell. Thanks.
    Old 07-09-2017, 11:55 PM   #14
    Tabman is currently offline
    Send Tabman:
    Here is he wiring for Boat Leveler (as we last checked).
    green=Port Valve
    white= Starboard Valve
    red=Motor Forward (pump pressure)
    yellow= Motor Reverse (pump retract)
    black on HPU=Ground
    red on Helm=Control Positive
    If I am correct on the wiring then here is how you can test it.
    Remove the wires from the helm control and touch together as follows:
    Operation=Reaction
    (+), Red, Green=Port trim tab down
    (+), Red, White=Starboard trim tab down
    (+), Red, Green, White=both trim tabs down
    (+), Yellow, Green=Port trim tab up
    (+), Yellow, White=Starboard trim tab up
    (+), Yellow, White, Green=both trim tabs up
    If the trim tabs function correctly for each wire grouping then the switch is at fault. Also note that any loose or missing screws on the back of the switch (whether a wire is connected there or not) can cause the pump to malfunction.
    This test may also be done right at the pump by using a hot lead. There is usually a connector to the wire harness within a foot or so of the pump. You want to check this connection for corrosion. You may wish to cut the connector off on the pump side and try the test on bare wires.
    If you test right at the pump and still no go, then the pump is at fault.
    If you suspect corrosion on the wire connector near the pump, cut it out, test as above and reconnect using butt splices.
    Here is a link to the Insta Trim / Boat Leveler website, Home - Insta-Trim Boat Levelers I could not find a troubleshooting guide there but confirmed the wiring colors so the troubleshooting should be good. It is worth going over this before turning it over to a mechanic since it is likely an easy problem to isolate and fix.
    I hope this helps, let me know if you have any questions.
    Tom McGow
    Bennett Marine
    Old 07-10-2017, 12:10 AM   #15
    Ok thanks. So the port hydraulic works going down now (on the switch) but it won't come up. with just the bare wires. I bypassed the switch using the system you told me. Is the hydraulic bad? Or a wiring issue buried somewhere
    Old 07-10-2017, 12:13 AM   #16
    chuse927 is currently offline
    My Model: 272z Barchetta
    My Engine: 7.4
    Send chuse927:
    Originally Posted by 1996 Mariah Z252 View Post
    Filled it with fluid, still has the same symptoms and doesn't work. https://youtu.be/-eS88p0G53c
    Need to bleed the air out. It should be a self bleeding system like the trim. Run then up and down like 5 times to bleed out the air
    Sent from my SM-N920V using Tapatalk
    Old 07-10-2017, 12:16 AM   #17
    I did that.
    Thank you 1996 Mariah Z252 for this useful post!
    chuse927 (07-10-2017)
    Old 07-10-2017, 01:20 AM   #18
    tbrookens's Avatar
    tbrookens is currently offline
    My Model: Shabah Z252
    My Engine: 454 Mag, Bravo 3
    Gallery Images: 2
    Send tbrookens:
    I think I would hold the switch for a while, or have someone hold the switch, while you exercise the tabs. You may need to do this to bleed the air out of the system. I just hard to believe that both actuators would go bad at the same time, and it sounds like the pump is building pressure.
    Tracy Brookens
    Old 07-10-2017, 01:23 AM   #19
    But that still does not solve the problem of the pump not responding when I touch the 2 wires together. It won't do anything when I simulate "bow up"
    Old 07-10-2017, 01:32 AM   #20
    tbrookens's Avatar
    Gallery Images: 2
    Send tbrookens:
    I'd tackle on thing at a time. Get the pump working again, and then work on the switch.
    Tracy Brookens
    Wanted: trim tabs eagleman201 Mariah Parts For Sale & Wanted 2 12-13-2015 03:39 AM
    Trim Tabs edward cossey Projects 2 07-15-2012 06:49 PM
    Key wont make a sound in the ignition after being winterized ndercole Mercury MerCruiser 2 05-30-2012 02:54 AM
    trim tabs ?????????? boat man2 Original Mariah Talk 6 07-07-2009 12:07 PM
    Total Threads: 13,324
    There are 320 users
