Wanting to test electrical without engine installed.
General Maintenance
Old 06-25-2017, 07:06 PM   #1
pole trick is currently offline
My Model: 180 Shabah
My Engine: 4.3 Merc
Send pole trick:
Default Wanting to test electrical without engine installed.
Hello all! We purchased a 96 180 shabah and are trying to check the electrical components on the boat while the engine is being rebuilt. We hooked up power to the battery mounts, but the power seems to be needed to run through the motor harness to energize the boat which is not hooked up do to engine is out. Any tips or tricks are appreciated!! Thank you!
  • Old 06-26-2017, 01:31 AM   #2
    GaryDoug's Avatar
    GaryDoug is currently offline
    My Model: Z202
    My Engine: 5.7L Bravo III
    Send GaryDoug:
    Default Re: Wanting to test electrical without engine installed.
    I believe all you have to do is: 1) connect together the two black wires that went to the engine ground stud and 2) connect together the large red (from battery) and small red wires that went to the starter. The smaller red wire should have (or had) the circuit breaker attached. If the circuit breaker went with the engine, then use the red-purple wire instead, but not the red-purple wire going to the starter solenoid or alternator. Do not connect the large red wire going to the starter solenoid to anything. Also, make sure that the 4 wires that went to the alternator are not connected to anything.
    Wanting new paint on my talari Txtruckerpaul Original Mariah Talk 0 07-12-2015 01:56 PM
    Wanted: 2004 Maria wanting a swim platform peterson2400 Mariah Parts For Sale & Wanted 2 08-27-2014 09:11 AM
    wanting bennett tabs on 2001 238 shabah Jshabah Original Mariah Talk 1 06-05-2012 06:38 PM
    Wanting carpet danheather Original Mariah Talk 2 07-14-2010 11:40 AM
    There are 364 users
