Radio shutting off at high volume.
General Maintenance
Old 05-24-2017, 01:36 AM   #11
Default Re: Radio shutting off at high volume.
Originally Posted by 1996 Mariah Z252 View Post
Crazy theory but, would I need a 2nd alternator to power the radio and other accessories? Just replaced my Alternator last July.
Sent from my iPad using Tapatalk
No. Lots of us running more than one battery. Only one alternator.
Sent from my XT1585 using Tapatalk
  • Old 05-24-2017, 01:37 AM   #12
    1996 Mariah Z252 is currently offline
    My Model: Z255 Shabah
    Send 1996 Mariah Z252:
    That's what I thought. Same here. 2 batterys, one Alternator.
    Thanks.
    Old 05-24-2017, 02:11 AM   #13
    GaryDoug's Avatar
    GaryDoug is currently offline
    My Model: Z202
    My Engine: 5.7L Bravo III
    Send GaryDoug:
    I assume you checked the fuse block. Because I had the EXACT same symptoms (radio dropping out at high volume and voltmeter fluctuation)
    Old 05-24-2017, 03:50 AM   #14
    pllevine's Avatar
    pllevine is currently offline
    My Model: 202 Shabah
    My Engine: 5.0L Alpha
    Send pllevine:
    Thanks.
    You normally don't run two alternators. It wouldn't be of any benefit. Alternators can be purchased in different current outputs.
    Phil Levine
    1998 202 Shabah
    Old 08-27-2018, 05:02 PM   #15
    95MTalari 180 is currently offline
    My Model: Talari 180
    My Engine: 3.0 GS
    Send 95MTalari 180:
    Mine just did this last weekend... going to check the fuse block which is under the console but wondering if the OP ever solved the issue.
    Old 08-27-2018, 09:16 PM   #16
    IF you are running some decent stereo equipment and other 'accessories' in your boat, a single battery and the stock Alternator just wont handle the power requirements over a period of time. I would suggest adding a 2nd battery with a switch control. One battery for starting the boat and one battery for all of the accessories.
    And while you're at it, swap out those old halogen bulbs for LED's and reduce the current draw wherever possible.
    5.0 merc shutting down schevel Mercury MerCruiser 3 06-30-2016 03:17 PM
    WOT RPM's too high KeepitReal Mercury MerCruiser 4 07-29-2011 02:19 AM
    High-pitched alarm sound & high temp at high RPM petemcrunnel Original Mariah Talk 7 06-15-2011 05:57 PM
    High Five grommett Prop Talk 15 04-27-2011 07:08 PM
    Total Members: 18,990
    Total Threads: 13,324
    There are 296 users
