Breaking out the boat
General Maintenance
Old 05-20-2008, 01:33 AM   #1
Straad's Avatar
Straad is currently offline
My Model: Barchetta 182
My Engine: 4.3 Merc
Gallery Images: 8
Send Straad:
Default Breaking out the boat
after a long winter stored away after being professionally winterized
what does one have to do, mechanically speaking
in the fall it was tuned up, oil changed, lower unit checked
i pulled the battery and stored it inside
boat stored in the garage
can i just hook up the earmuffs
charge the battery and start it?
Straad
1995 Barchetta 182, 4.3L
Southern Mid-Michigan
  • Old 05-20-2008, 02:28 AM   #2
    jmills224's Avatar
    jmills224 is currently offline
    My Model: 1997 179SE Talari 4.3LX Gen+/Alpha1 Gen II
    Gallery Images: 4
    Send jmills224:
    Bring it up to temperature. After you run it for a while I would change your fuel filter and after my experience with faulty manifolds. I would suggest pulling the oil drain plug and catching a sample of oil to check for water. Check your fire extinguishers, load up the life preservers, emergency gear/first aid kit, water toys, and ice chest. Then.......hit the lake
    Old 05-23-2008, 03:15 PM   #3
    Straad's Avatar
    My Engine: 4.3 Merc
    Gallery Images: 8
    Send Straad:
    so right into the water and bring her up to temp huh?
    ok kewl
    how hard is it to get her started after winterization
    will it kill the battery turning over
    last boat i had a guy i know winterize it and he would choke out the carb when done by pouring oil into it while running...is that common?
    seems that would be awful hard to get started again
    Straad
    Old 05-23-2008, 03:31 PM   #4
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Choking the engine after putting in the fogging oil is the preferred way of winterizing the cylinders. By the time you run to the ignition switch, the oil in the cylinders has burned off...
    Mine was winterized by my guy at the marina. I picked it up last weekend, drove to the launch ramp, put the plug in, dropped it in the water, gave the accelerator two pumps, cranked it for about 3 seconds before it fired right up.
    I let it idle for a few minutes to get it up to temp, and away we went.
    My Mariah
    Old 05-23-2008, 03:37 PM   #5
    I had exactly the same experience with mine last year. Haven't fired it up yet this year but expect the same again.
    Old 06-06-2008, 05:58 PM   #6
    Straad's Avatar
    My Engine: 4.3 Merc
    Gallery Images: 8
    Send Straad:
    sweet thanks
    cant wait
    89' today and 92' on sunday
    thats michigan for ya, we had a frost advisory monday...LOL
    Straad
    Thoughts on breaking in a new engine bblauvelt Original Mariah Talk 8 03-07-2008 01:26 AM
    There are 296 users
