Best Motor Oil for 1998 Mariah Cruiser 28'
What is the recommended best motor oil for 1998 Mariah 28'???
Thanks a Lot |
Re: Best Motor Oil for 1998 Mariah Cruiser 28'
Depends on which motor you have. I have a 7.4 Volvo, recommended oil is 20-50 Volvo Penta, expensive, I use Royal Purple 20-50 full synthetic.
Thanks, but my motor is a Mercury 7.2 Lts
Mercruiser recommends Quicksilver 25W-40 Marine engine oil. I use it when I can get it. More often than not I use a straight 40W oil that is more readily available in auto stores. Note that the SAE 40 is only good at temperatures above 50F (10C).
Thanks, some people recommended use PENNZOIL Rotella T SAE 15W-40 Diesel Engine??? that is true ????
It's your choice. I would not use it. The 15W is pretty thin. The 7.4L has fairly low oil pressure at idle and the thinner oil will not help.
I use the Valvoline VR 20W-50. I want as much zinc as I can get. (I know Hudson, it's a roller but I'm hard headed thata way). Full synth is best but the more important thing is the filter.
Arguments? I use either the K$N or Mobil1 Extended. The filtering media is unbeatable. Just don't put anything orange on it. Again....arguments? |
| All times are GMT. The time now is 07:25 PM. |
