-   -   Steering wheel play. (http://www.mariahownersclub.com/forum/general-maintenance/10790-steering-wheel-play.html)
Unknownmariah 05-24-2016 02:10 PM
So I have about 4 inches of play in the steering wheel during slow speeds...is this normal? How can I reduce this?
Hudson River Steve 05-24-2016 04:19 PM
Re: Steering wheel play.
Sort of normal. You can get play due to steel pin in aluminum housing. Can also get some slop due to pin at tiller and in the steering box. When they all add up you can have quite a bit of play. It is expensive to make like new.
Unknownmariah 05-24-2016 04:42 PM
So basically there is nothing I can by myself to fix or reduce it?
Hudson River Steve 05-24-2016 07:14 PM
You can start by checking that the connection nuts at both ends of the steering cable are tight. After that it is basically replacing parts.
