Shrink wrap repair
Boating 101
Old 02-05-2011, 12:44 PM   #1
E andJRX19 is currently offline
My Year: 2009
My Model: rx18
My Engine: 3.0 tks
Send E andJRX19:
Unhappy Shrink wrap repair
When I was trying to clean the 2 feet of snow off my boat I noticed 2 small tears on my shrink wrap. Does anybody know if there is something I can use to cover that. I dont want any moisture to get in and the tears are not very big. I should of left the snow alone!
  • Old 02-05-2011, 02:11 PM   #2
    Default Re: Shrink wrap repair
    Duct tape should work okay.
    Old 02-05-2011, 07:53 PM   #3
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    And look classy as well!
    Old 02-07-2011, 02:49 AM   #4
    My Year: 2009
    My Model: rx18
    My Engine: 3.0 tks
    Send E andJRX19:
    I was going for the duct tape thing, thanks
    Old 02-08-2011, 04:40 AM   #5
    al levy is currently offline
    My Model: 272 shabah
    My Engine: 7.4 bravo 111
    Send al levy:
    duct tape does not always hold. call the installer and buy some shrink wrap tape or call your local marina i am sure they will have it. when you put the tape on cross 2 pieces it works better that way and if possible use a hair dryer.
    Old 02-09-2011, 12:51 AM   #6
    My Year: 2009
    My Model: rx18
    My Engine: 3.0 tks
    Send E andJRX19:
    sounds good, thanks for the suggestions
    Old 02-09-2011, 05:21 AM   #7
    Send al levy:
    i should have told you also if the hole is big enough and you can get a piece of wrap and tape, place the wrap on the original wrap and hold it down with 4 pieces of tape like a patch. heat the tape till it shrinks and then heat the new piece of wrap. that will be a perfect repair
    hull repair candanewell Original Mariah Talk 5 05-09-2010 08:32 PM
    Skeg Repair sweetness34 Mercury MerCruiser 6 03-11-2010 12:33 PM
    Gel coat repair Threejakes Original Mariah Talk 5 04-05-2009 11:10 PM
    94 Talari repair Brian Mercury MerCruiser 3 03-14-2009 03:51 AM
    hull repair bpfirrman General Maintenance 5 04-30-2008 02:31 AM
    There are 265 users
