Drive lube oil
Boating 101
Old 07-31-2008, 09:45 PM   #11
Brian's Avatar
Brian is currently offline
My Model: 1994 Mariah Z200 Talari Merc 4.3L 180hp, Alpha 1
Gallery Images: 21
Send Brian:
Default Drive Oil
removed the lower drain plug on the outdrive and out came fresh looking gear oil. I believe this was a good sign. I will stop off at the dealer tomorrow to check on the price and availablity of the parts needed. I will look through the web page to see if the how to's give details on this process of outdrive removal and seal replacement.
Brian
  • Old 07-31-2008, 10:57 PM   #12
    jmills224's Avatar
    jmills224 is currently offline
    My Model: 1997 179SE Talari 4.3LX Gen+/Alpha1 Gen II
    Gallery Images: 4
    Send jmills224:
    The drive removal is going to be the easy part. If it turns out to be your gear end yoke seal thats going to get progressively more difficult. You will need a torque wrench and a special spanner wrench for the castle nut that holds your gear end yoke/bearing pack in the upper gear case. Also, if your seal is leaking its probably because at some point it got water into the bellows and rusted/pitted your gear end yoke. Yoke replacement requires a bit more savvy.
    While your at the part house go ahead and get a mercruiser manual for your drive. Read up on pulling the drive and pull it to see what you got. If you got oil in your bellows then start reading up on seal and probably yoke replacement. If its something you want to tackle then give it a shot...you can save alot of money. If it looks too involved don't be afraid to load up your drive and take it to the mechanic of your choice.
    ~J
    Old 11-28-2008, 07:23 PM   #13
    mkasch is currently offline
    My Model: 1997 SE SHABAH
    Send mkasch:
    Default Drive Oil
    I also had the same problem and warning sound would stay on after ignition turned on. My mechanic took everything apart because there were no leaks but had oil in bilge . He resealed everything and problem was solved for 400 dollars ouch.
    THE LUZZ99
    Old 03-22-2009, 05:59 PM   #14
    AirNavy's Avatar
    AirNavy is currently offline
    My Model: Z215 Talari
    My Engine: 5.7L Alpha One
    Send AirNavy:
    Default Re: Drive Oil
    Old thread, but here's a link to some good info for good measure: http://www.mercstuff.com/howdoi.htm
    Mickey
    AEC (AW) U.S. Navy
    Old 08-08-2009, 04:22 AM   #15
    Sin or Swim is currently offline
    Send Sin or Swim:
    Default Re: Drive lube oil
    Originally Posted by S.L.P. View Post
    Brian,
    I recently had a similar problem w/ my Bravo III. Slowly losing drive oil, could not see any on the water, none in the bilge and none around the reservoir. Turns out the seal in the outdrive to transom was leaking. All the missing oil was inside the bellows. a new seal fixed everything. After running for several hours the oil level stabilized and topped i t off with an ounce or two and had no problems since.
    good luck
    steve
    Hi there! we are having the same problem with our oil disappearing....as brand new boaters I need to ask...this oil in the bellows, can it damage anything? If that is indeed where the oil is going, can we still use the boat or should we pull itout immiediately and get this fixed?
    Thanks for your thoughts!
    Old 08-10-2009, 12:19 AM   #16
    S.L.P. is currently offline
    My Model: 2000 Z260 MCC 7.4L MPI BravoIII
    Send S.L.P.:
    ck for water in the outdrive. If it looks milky, fix it as soon as possible.
    The oil in the bellows shouldnt have too much of an immediate detrimental effect , but it shouldnt be there. Have it serviced as soon as you can. If the outdrive hasn't been removed and serviced in the past few years, then it time to git it done. Check the condition of the bellows also.
    The Muskrats around home have developed a taste for bellows and transducer lines.
    I need a good recipe for Muskrats:
    2000 Z260 7.4L Bravo III
    Z250 Drive and Props UKZ275 Mercury MerCruiser 0 03-13-2008 07:21 PM
    crashed hard drive!! moondance100 Introductions 4 11-29-2007 04:14 AM
    Alpha Gen II Drive Coupler Captain Steve Mercury MerCruiser 3 10-22-2007 06:40 AM
    what a drive home 180diablo Chit Chat/Off-Topic 7 09-17-2007 03:28 PM
    used engine/drive parts MariahShabah3.0 Yamaha, OMC, and Other Engines 0 08-29-2007 12:33 AM
    There are 240 users
