Original mariah key
http://uploads.tapatalk-cdn.com/2016...a7981735e0.jpg
Has anyone ever gotten the key cover off and put it over new keys when they're ignition module went? |
Re: Original mariah key
Yep. If you look close, you can see the small slot to pry open from.
Im all over that like a fat kid on a cupcake!!! U think it can be done brian? Trying it first thing in the am
1998 shabah 180 5.7l 350 mag Bravo III |
Yes. I opened mine this way only to decide to buy the entire key with FOB (?). My key is broke off in the ignition so I kinda got to. Also, I have a cabin door with a matching lock.
I would have done it like you're going to do nut I cant get the keyed part out of the switch. But yes, I opened mine up to see that it is a regular key glued inside and then the whole thing was glued together |
| All times are GMT. The time now is 10:14 AM. |
