Need help with a trim/tilt problem 78 check mate Johnson motor
Yamaha, OMC, and Other Engines
Old 05-12-2014, 01:47 AM   #1
Ptrmundschau is currently offline
My Year: 1978
My Model: Check mate
My Engine: 85 javelin
Send Ptrmundschau:
Default Need help with a trim/tilt problem 78 check mate Johnson motor
i just bought a little 15 foot check mate with a 85 horse javelin motor.. the trim seemed to have a bit of a problem as it blows the 25 amp fuse in the relay box. i just bought a few fuses to keep on hand and took it out over 5 times with no problems. now this past weekend the trim completely stopped working. i figured it was the fuse again and it wasn't.. the fuse was fine. when i hit both up and down on the tilt control absolutely nothing happens. there is no clicking coming from the solenoid. i cleaned and scrubbed every single connection in the relay box and still nothing. please help!!
do i just have to replace the solenoid?
could this be a short?
  • Old 05-12-2014, 02:43 AM   #2
    Default Re: Need help with a trim/tilt problem 78 check mate Johnson motor
    Welcome to MOC
    You do realize you are on a MARIAH boats site , right?
    That being said ,
    I would clean all contacts positive and negative on the trim system.
    Then I would start by seeing if there is power going to the solenoid and then coming out of the solenoid
    If so check power at the trim pump motor itself. If you have power all the way to the trim pump motor and it still doesn't work , I'd say the trim motor itself is bad.
    THIS might help you a bit also.
    Once again , Welcome!
    Old 05-12-2014, 03:13 AM   #3
    Thanks for stopping by but you might be better served over at the iboats.com forums where they have a specific section for Johnson outbards.
    Old 06-09-2016, 03:41 PM   #4
    dafucwuzat is currently offline
    My Model: talari 221
    My Engine: merc 5.7 b3
    Send dafucwuzat:
    Or solenoids.
    checkmate , johnson , solenoid , tilt , trim
    Tilt/Trim jsewall82 Original Mariah Talk 29 08-30-2013 03:48 PM
    Tilt/Trim Trailer use Lucky14 Sea Fox - Mariah Talk 2 08-22-2013 06:18 PM
    Trouble Shooting your Power Trim & Tilt Motor System mikeyt General Maintenance 0 07-03-2012 10:58 PM
    Tilt problem rmco7 Introductions 2 05-10-2012 02:33 AM
    SX19 4.3 Alpha 1 Tilt motor bracket rusted Mariner Mercury MerCruiser 2 06-18-2010 09:05 PM
    Total Members: 18,510
    Total Threads: 12,950
    There are 165 users
