Captain's call exhaust and swim platforms.
Watersports
Old 05-20-2012, 03:17 PM   #1
TexasZ212's Avatar
TexasZ212 is currently offline
My Engine: 5.7 Mercruiser Alpha 1
Send TexasZ212:
Default Captain's call exhaust and swim platforms.
I know that generally when the Corsa/Captains Call exhaust can't exit below/under the swim platform, then you go to side exits.
But, the factory rear exiting Mariah tips are so beautiful that if you had a set of those already...along with the expense of buying a set of side exit exhaust tips to replace your o-so-beautiful factory Mariah tips...well, it makes one want to use those o-so-beautiful exhaust tips, no matter what.
I love the swim platforms that members here are adding to their Mariah's, and along with the reviews, agree when everyone usually says it's the best and most enjoyable addition to their Mariah that they have ever done.
I love the swim platforms that are available in every way except one. For me personally I wanted a swim platform that the top surface of the swim platform will be even/level with the surface of the water when the boat is stopped...like the Malibu Wakesetters and several other brands that are made/designed primarily as a wake board craft.
I was just reading some of the last posts to the "new swim platform" thread and saw once again comments about the difficult space restrictions on some of our boats to make the exhaust tips exit below/under the swim platform.
I'm curious and just have to ask, what if there wasn't enough room underneath the swim platform to exit there, and the exhaust tips ended up exiting just above the swim platform?
I ask this cuz' my son and I custom made our own swim platform for the back of our 1999 Z212 Shabah...and it does sit level with the water surface when our Mariah is stopped. In order to accomplish that, we had to make the swim platform attach lower that the ones being made for our boats by the commercial manufacturers.
The factory Mariah exhaust tips are exiting above the swim platform.
I fought with that decision long and hard and thought about all the potential problems (mainly safety) that might occur from having them exit above the swim platform...exhaust fumes...tips being hot after running hard...and on and on and on...but we haven't had any problems at all, none, zero...and I sure like being able to see the factory Mariah exhaust tips, not to mention hearing the rumble when they are switched on.
James
1999 Z212 Shabah
5.7 V8 Alpha 1 Gen ll
  • Old 05-20-2012, 03:51 PM   #2
    jarwiebe's Avatar
    jarwiebe is currently offline
    My Model: Z210 Shabah
    My Engine: 5.7 LX Alpha I
    Gallery Images: 2
    Send jarwiebe:
    Default Re: Captain's call exhaust and swim platforms.
    Would it be possible to post up up some pic's. I am thinking of building my own as well and mounting it at water level. My question is, how did you deal with the out drive when you put into trailer position? Did you need to adjust the it so it wouldn't come up as high as normal, if so, how is that done?
    Cheers
    Jake
    1996 Z210 Shabah
    Mercruiser 5.7LX
    Alpha One Drive
    80 Lb. SX Smart Tabs
    Old 05-21-2012, 12:46 AM   #3
    TexasZ212's Avatar
    Send TexasZ212:
    I'll take some pictures and post them when I can. I wanted to wait until I had the time to write an explanation to go along with the pictures.
    Good question about the out drive. I don't know for certain how much higher it would go if the swim platforn was't in the way, but I don't think it would be more than about three inches.
    It "will hit" the bottom of the platform if you try to put it up as far as it will possibly go. It goes plenty far up to never ever have a problem with it dragging on anything.
    My wife is usually the one that drives our boat onto the trailer. We have a small mark about a 1/4 inch from the top on the trim gauge that we use as a guide so we don't raise the outdrive too high in the trailering position. Once out of the water where we can visually see it, we simply raise it those last few inches with the outdrive switch that is located at the back of the boat.
    I'll wait until I put the pictures up to explain the reasoning behind why we made ours the way we did.
    James
    1999 Z212 Shabah
    Old 05-21-2012, 03:31 PM   #4
    nglauer's Avatar
    nglauer is currently offline
    My Model: 180 Diablo
    My Engine: 3.0L Alpha one
    Send nglauer:
    I would like to see pictures as well. I would love to have a swim platform and have thought about making one for our boat. I'm just not sure if I should go fiberglass or teak. I could easily make one from wood, but I'm not sure how it would look on a boat like mine. Very interested in any pictures or details you can offer.
    Nick
    odis1943 likes this.
    Old 05-21-2012, 10:18 PM   #5
    rayzorback's Avatar
    My Model: 210 LE
    My Engine: 454 Bravo 1
    Gallery Images: 10
    Send rayzorback:
    I'm interested to see the pics too. My wife would have liked to have the swimdeck closer to the water, but I personally didn't want the exhausts above the swimdeck. after running my boat a few times, I notice dark areas developing on the underside of my new deck from the exhaust fumes. I wonder if it would do that on the top side if the deck were below the exhausts.
    Old 05-22-2012, 10:05 AM   #6
    TexasZ212's Avatar
    Send TexasZ212:
    No dark areas/spots/stains/nada at all on mine. Before you get up on plane, the swim platform gets covered with water so it gets a good wash off every time you throttle up to make the boat plane.
    Hang in there with me, I promise to get some pics up here soon. I've had some long days and nights. If you notice the time of this post you will see it's at 5 AM Tuesday morning, and I just come in from working on my son's projects and we started at 8 AM Monday morning. I'm 64 and way too old to be working 20 hour days.
    James
    1999 Z212 Shabah
    Old 07-08-2012, 03:38 PM   #7
    caraudio91 is currently offline
    My Model: 212z
    My Engine: 350/alpha one
    Send caraudio91:
    i have a z212 as well and was thinkin bout building a swim deck out of the off white marine anti skid wonderboard?would love to see some pics of your boat? i put thru hull exhaust on my boat and it sounds great too
    Old 06-25-2013, 11:00 PM   #8
    Deckard83 is currently offline
    My Model: Z212 shabah
    My Engine: 7.4l bravo III
    Send Deckard83:
    I am looking as we'll. if I went below the exhaust would you be able to trim up the motor to trailer mode? My wife is on the hunt for one. I'm not to sure I do I'm afraid i will loose the sound of exhaust.
    Deckard83
    1999 shabah z212. 7.4, 454
    Old 06-25-2013, 11:31 PM   #9
    Deckard83
    The two boats I have been around that added a swim deck to a boat with captain call have gotten exponentially louder once the swim deck was put on.
    I don't know how that will be effected by putting the deck below the exits though...
    Old 06-27-2013, 01:43 AM   #10
    Send Deckard83:
    I looked into the platforms today. I found some nice ones I just not sure if I could deal with having to drill holes in the boat for the mounting brackets!!!! I'm sure others haven't had any trouble with leaking I hope?
    Deckard83
    1999 shabah z212, 7.4, 454
    Bravo III
    Swim Platforms rooperdan Projects 8 05-31-2015 09:01 PM
    Captain's Call Information Please spinks99 Projects 4 11-11-2011 01:14 PM
    Captain's Call Exhaust 2000Z272 Projects 5 05-23-2011 03:28 PM
    Added Captain's Call... Oh boy, oh boy, oh boy!!!! indykoch Projects 12 11-20-2010 04:37 PM
    Some helps with Captain's Call operation stereoman405 Original Mariah Talk 7 05-21-2009 03:28 PM
    Total Members: 18,524
    Total Threads: 12,958
    There are 108 users
