-   Volvo Penta (http://www.mariahownersclub.com/forum/volvo-penta/)
-   -   Help with trim promblem (http://www.mariahownersclub.com/forum/volvo-penta/9358-help-trim-promblem.html)
johnmcgowan 05-27-2014 05:46 PM
I have a 2000 Jubilee with the dual prop Volvo outdirve. Had and issue with the trim, would not come up when I put on the trailer. The relays click when the switch is pressed either up or down. Test 12v to motor. Put 12 v direct to motor from battery and the motor works, was able to get the outdrive up this way. Is there a ground switch somewhere I am missing? Any ideas?
Help is very much appreciated.
ColoradoDiablo 05-27-2014 06:00 PM
Re: Help with trim promblem
Welcome to MOC john!
Sorry to hear the problem.
Take a look HERE for help on diagnosing the trim system. :)
johnmcgowan 05-27-2014 06:07 PM
Thank you for the reply.
The link did not come through, could you send again?
mikeyt 05-27-2014 06:13 PM
Try this link. STICKYS for repairs & troubleshooting are located at the top of the General Maintenance forum.
ColoradoDiablo 05-27-2014 06:29 PM
Thanks Mikey!:wink_thumbup:
drneffga 05-29-2014 03:02 PM
Mine sticks at the beginning of the season or when I don't use it for a few weeks. I just hold it for a while and it eventually works.
mikeyt 05-29-2014 03:08 PM
You dont want to burn out the motor or solenoids. Take an hour or so and clean the connections.
