-   Trailering and Tow Vehicles (http://www.mariahownersclub.com/forum/trailering-tow-vehicles/)
-   -   Trailer Wheel Bearings (http://www.mariahownersclub.com/forum/trailering-tow-vehicles/576-trailer-wheel-bearings.html)
WetWilly 07-18-2008 09:45 PM
Originally Posted by bpfirrman (Post 8996)
I recently had my bearings replaced and I have bearing buddies. I don't think the mechanic put enough grease in the buddies, I have the newer type with the blue ring. Their website states that the blue ring should be sticking out beyond the chrome ring. Do I just add grease until I see the blue ring come out 1/8 inch? I tried adding a few pumps and it did not move. I have little experience with bearing buddies and do not want to overfill and blow a seal.
Hi bpfirrman,
Says on their site that the BBs have an automatic pressure relief feature that prevents over-filling and over pressurizations (click here) so you should be OK and yes, if the ring isn't showing, you need more grease.
To be safe, I'd give them a call - 787-839-2688
