-   Trailering and Tow Vehicles (http://www.mariahownersclub.com/forum/trailering-tow-vehicles/)
-   -   Trailering switch (http://www.mariahownersclub.com/forum/trailering-tow-vehicles/5034-trailering-switch.html)
wcso909 11-04-2010 03:46 PM
Trailering switch
Can anyone tell me where the original location is for the trailer switch on a 1996 Shabah? I purchased my boat in October and the console was destroyed thanks to the previous owner's attempt to install a new radio. I am going to rebuild the console in the spring however I had to bypass the trailer switch when I went to winterize my boat this week. Was the switch on the shift or the console?
Thanks for the help. I am trying to draw out my wiring diagram using the "console" posts on here.
scubydo 11-05-2010 02:38 AM
Re: Trailering switch
On my 96 Shabah is is on the back lower corner of the Base of the throttle lever. I bought the boat a few months ago, and it was hell to find it, but it's there. There is also one on the Transom.
wcso909 11-08-2010 02:36 AM
Thanks for the help. You must have bought your boat around the same time, I bought mine. I did find the button on the bottom of the throttle. I am still looking for the one near the transom.
ShabahZ280 11-08-2010 10:11 PM
To the best of my knowledge, the transom switch is an option only available on the Z-series models.
wcso909 11-08-2010 10:24 PM
Shabazz250, scubydo and simpleaz, thank you very much for your input. I thought I was losing my mind. It's my first boat/Mariah and I am still learning.
Thanks again.
simpleaz 11-09-2010 03:26 AM
I am learning each day. Mine is a Standard 200 but I do have the transom switch. Handy when getting on trailer and helps me not forget to put up the drive.
Best to you. Lots of good info on here. I went ahead and bought the lifetime membership as I plan on being around awhile.
scubydo 11-09-2010 04:47 AM
My 96 200 is not a "Z" and it has the transom switch as well.
simpleaz 11-09-2010 05:17 AM
The 200 model I think was only made in 1996 so maybe it was just standard on this model. I do like the lines of mine. They are a little different from the other models from what I can tell.
ShabahZ280 11-10-2010 12:39 AM
Perhaps the transom switch was standard on the 1996 200 model, in 1997 the "Transom Tilt Switch" was listed as part of the Z Package. So you guys got a "Free Z Perk" :D
wcso909 11-10-2010 04:05 PM
Odd. Mine does not have it and it is a 1996 200 Shabah. I have just put her up in for the winter. I am reviewing all the posts on here and I am going to overhaul her from bow to stern come the spring.
