Stern drive position while trailering?
I recently heard a friend mention that the sterndrive should be lowered once the boat is on the trailer and you're ready to hit the road... I never heard this before, I just assumed the sterndrive stays up while you're trailering. Anyone know the right answer here? Or, does it matter or depend which sterndrive unit it is?
Re: Stern drive position while trailering?
Unless you want the skeg ground down to a nub, put it in the full, up position. The only boats I've seen in the down position are huge offshore powerboats that sit high on the trailer and have the clearance necessary. Even then, I don't understand why you wouldn't have it up (maybe those performance drives don't really have a "trailer" position).
Indykoch is right, that's why there's a "Trailer" button on the trim... The only time it's recommended to have the outdrive down when on a trailer is when you're planning to store your boat on the (parked) trailer for an extended amount of time, having the outdrive down helps relieves tension on the bellows to minimize cracking. I don't lower the outdrive from "trailer" position until our Talari is launched and floating on the water. WetWilly |
+3. If its my stern drive, its in the trailer up position. Maybe your 'friend' doesn't like you? ;)
Jim |
OK thanks to all, that's what I've always thought and done anyways... maybe my "friend" is jealous of my recently acquired 252. I'll tell him he's right, the drive should be lowered while trailering, as he has a new Bayliner so he'll see what happens first hand!!:shakehead:
I'm sure he'll appreciate your conformation and support and you get the satisfaction of knowing that you just helped him with with making a performance mod to his new um, boat by helping to reduce water drag and weight, oh yea :yes_grin: WetWilly |
| All times are GMT. The time now is 01:32 PM. |
