Replacing 4.3L Alpha One Water Pump Impeller?
Mercury MerCruiser
Old 06-24-2013, 08:04 PM   #1
SEMIJim's Avatar
SEMIJim is currently offline
My Model: 182 Barchetta
My Engine: 4.3L Alpha 1 Gen. 2
Send SEMIJim:
Default Replacing 4.3L Alpha One Water Pump Impeller?
Hi,
Has anybody here ever tried this: How to Replace an Impeller on a MerCruiser Alpha One.
Seems pretty darn straight-forward. Doing it that way: Draining/refilling the gear oil isn't necessary.
Only thing I'm wondering about is this bit:
2. Mark the position of the trim tab. Remove the Allen screw that holds the trim tab in place and remove the trim tab.
Picturing our boat's outdrive, in my mind, I cannot imagine what they're talking about.
Thoughts? Experiences?
Jim
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Click Here --> Help Support The Mariah Owner's Club <-- Click Here!
  • Old 06-24-2013, 08:23 PM   #2
    Default Re: Replacing 4.3L Alpha One Water Pump Impeller?
    Never really had much faith in EHOW. Your gonna loose drive oil! No way around it.
    Here is the proper way Jim
    Lots of info to boot!
    Old 06-25-2013, 02:21 AM   #3
    SEMIJim's Avatar
    Send SEMIJim:
    Thing is: When our boat was repaired, first season we had her, a mechanic hadn't gotten something Quite Right when he put the outdrive back together, and, IIRC, the shifter wouldn't shift in one direction or another. The service manager knew from the symptoms, right off, what was wrong. He had her hauled back out, dropped in an empty rack so the outdrive was about where it'd be if the boat was trailered. got some tools, carefully dropped the bottom, fixed it (it was a linkage that wasn't in the Right Place), and put it back together.
    Not a drop of fluid anywhere.
    So if the water pump can really be reached by just dropping the bottom of the lower unit...?
    Thanks for the link! Bookmarked!
    I think I'll call that place and ask them how much they'd charge to replace the impeller, and when they could get to it.
    Jim
    Old 06-25-2013, 03:42 PM   #4
    I've done it at the lake and it ain't no fun.
    All you got to do is make sure that it is in forward position when you reinstall the lower.
    Didn't loose a lot of gear oil , but did loose some. Maybe that drive had a seal leaking a little , I don't know.
    I'd be changing the fluid if I went that far anyway.
    JMO
    Old 10-03-2014, 03:01 AM   #5
    Smokymance's Avatar
    Smokymance is currently offline
    My Model: 182
    My Engine: 4.3L MerCruser Alpha 1
    Send Smokymance:
    How often are you guys changing your drive water impeller ? I see many talks staying yearly or every two ears.
    182 Barchetta 4.3L 4BBL V6, Alpha One, 21P SS Prop, 60# SX Smart Tabs.
    Old 10-03-2014, 03:19 AM   #6
    Every 3-5 yrs. If you spend a lot of time in shallow sandy lakes or put a lot of hours on the boat each year then maybe every 2-3 yrs. Anything more often than that is over-kill.
    Old 10-03-2014, 01:10 PM   #7
    Smokymance's Avatar
    My Model: 182
    Send Smokymance:
    Perfect thanks, Im assuming no way to tell if its going bad...maybe overheating issues at low RPM? ill have to find out when mine was replaced last.
    Old 10-03-2014, 03:45 PM   #8
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    Originally Posted by Smokymance View Post
    Im assuming no way to tell if its going bad....
    A small modification I do is cut the hose from the transom shield to the circulating pump and insert a piece of clear tube.
    I've done it on all my boats, (must get around to doing it on this one!)
    As soon as you fire the motor up you can then see water flowing through the pipe
    mikeyt likes this.
    Old 10-03-2014, 06:11 PM   #9
    Smokymance's Avatar
    My Model: 182
    Send Smokymance:
    THat makes sense...id like to see how you do it...good idea.
    Old 05-12-2021, 11:45 AM   #10
    MR2NR's Avatar
    MR2NR is currently offline
    My Model: Barchetta Z
    My Engine: Reman Vortech 4.3 A 1
    Gallery Images: 7
    Send MR2NR:
    Bringing this thread up. What Impeller replacement kit do I need for a Alpha 1 for my 93 Barchetta with the 4.3LX? Is it a gen 2?
    Replacing Seawater Impeller, Should I replace Pump too? allz28 General Maintenance 3 03-17-2013 03:53 PM
    5.0 Alpha One Impeller Replacment julrich_32 Projects 2 05-20-2011 02:41 AM
    Replacing Water Pump Impeller PROPNUT Mercury MerCruiser 8 04-18-2009 02:22 AM
    Water Pump Replacment- Alpha Gen2 DIY?? kadasia Original Mariah Talk 1 06-28-2008 09:20 PM
    Seawater pump impeller Paul Z General Maintenance 1 05-01-2008 02:50 AM
    Total Members: 18,518
    Total Threads: 12,955
    There are 214 users
