Sloppy steering
General Maintenance
Old 05-19-2011, 09:49 PM   #1
MinnetonkaMariah is currently offline
Send MinnetonkaMariah:
Default Sloppy steering
The steering on my Z225 Davanti has always seemed sloppy to me.
There is "play" in the wheel, where I can turn from 10 to 2 with no affect.
I often feel like a first time car driver over steering all the time, and at low speeds I am constantly playing with the wheel to keep her straight.
Is this normal?
Any thoughts will be appreciated.
Thanks!
Doug
  • Old 05-19-2011, 10:02 PM   #2
    csterner's Avatar
    csterner is currently offline
    My Model: Z275ST Shabah
    My Engine: 6.2L Bravo III
    Gallery Images: 9
    Send csterner:
    Default Re: Sloppy steering
    I think there is a procedure for adjusting your steering system. Check in the manual section of this forum. I think I saw it in there somewhere.
    2001 Shabah Z275 ST
    6.2L Merc with Bravo III
    Old 05-20-2011, 05:05 PM   #3
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    10-2 is a lot and csterner is right. But, also note that low speed wandering is common in deep V boats. There are a few threads about it on every boating forum that I'm on.
    Old 05-20-2011, 05:57 PM   #4
    Rick Smart is currently offline
    My Model: z272
    My Engine: 7.4 Bravo III
    Send Rick Smart:
    Slow speed wandering in the steering is normal. If boat is planed of and you have that much steering play you have a mechanical problem. Possible low fluid level, worn gimbel bracket, loose steering cable nut(s), worn steering helm. However be careful until the problem is fixed. I suggest not operating the boat until repairs are completed. Rick
    I'm now a proud owner of a Z272 and love it.
    Old 05-20-2011, 07:35 PM   #5
    edward cossey's Avatar
    edward cossey is currently offline
    Status: Ed Cossey ( sonny boy )
    My Model: 1998 Z252 Shabah Mercr
    My Engine: 7.4L Bravo 111"
    Gallery Images: 4
    Send edward cossey:
    my mariahs 252 steering wheel has about 3inches play in it i have to correct it at slow speeds, but at faster speeds its fine i had it checked out by a mechanic and he says its normal,
    all the best
    ed cossey
    Old 05-20-2011, 10:16 PM   #6
    rooperdan's Avatar
    rooperdan is currently offline
    My Model: 1998 SHABAH 210
    My Engine: Built 350 Alpha Drive
    Gallery Images: 10
    Send rooperdan:
    Most V - hull boats do wander, even with tight steering.
    Quietly Making Noise
    Old 08-20-2019, 02:15 AM   #7
    Gene is currently offline
    My Year: 2006
    My Model: Sx 18
    My Engine: 3.0 Alpha one
    Send Gene:
    I have a SX18 2006 with 3.0 /alpha one and I can steer the thing at low speeds at all .it is all over the place and seems like it doesn’t turn till the wheel is turned at least half a turn then you have to steer back the other way seems dangerous Also I see where the end of the steering cable goes into the actuator thingy it moves a couple inches before the boat starts to turn could the pump have low pressure when at lower RPMs ?
    Old 08-21-2019, 12:20 AM   #8
    How Do I by Mercstuff.com
    Old 08-21-2019, 10:43 AM   #9
    zrbart2000 is currently offline
    My Engine: 4.3 alph LH
    Send zrbart2000:
    Thanks mikeyt. I redid everything in the back end of the outdrive before I condemed my rack. There are some great things on your post.
    mikeyt likes this.
    Old 01-27-2020, 04:41 PM   #10
    Itwrx's Avatar
    Itwrx is currently offline
    My Model: Barchetta 182
    My Engine: 4.3 v6 Alpha 1 Gen II
    Send Itwrx:
    I had horrible wondering at low speeds. However after adding smart tabs it’s %100 better. Almost no wondering if any. Best mod to date.
    Tight steering Royster Original Mariah Talk 5 05-30-2013 04:40 PM
    Wanted: steering wheel limarian Mariah Parts For Sale & Wanted 6 08-12-2010 07:11 PM
    Hard Steering Kirkyer Introductions 0 07-19-2009 12:53 PM
    hard steering duketter Original Mariah Talk 2 06-07-2009 02:47 PM
    Hard steering Jimh23 Original Mariah Talk 4 06-05-2009 10:52 AM
    Total Members: 18,518
    Total Threads: 12,952
    There are 154 users
