Water in engine oil
Mercury MerCruiser
Old 07-28-2021, 02:40 PM   #1
jamiefoz is currently offline
My Model: 183 Shabah
My Engine: Mercruiser 4.3 Alpha
Send jamiefoz:
Default Water in engine oil
I have a 4.3l mercruiser V6 and when I checked the engine oil a few weeks ago it was very creamy, so I drained it and was advised to change the intake manifold gaskets which I did and cleaned out the crack case as best I could. Having replaced the intake manifold gaskets, oil and oil filter I took it on a test run for a couple of hours and having checked back in the engine, the oil is back to the same creamy state it was in before. Is there anything else that could be causing it apart from head gaskets or a cracked block? I have done compression tests on each cylinder and they are all very similar so I find it hard to believe that it would be the head gaskets.
Thanks in advance,
Jamie.
  • Old 07-29-2021, 02:27 AM   #2
    Tlolesen's Avatar
    Tlolesen is currently offline
    My Model: 182
    My Engine: 4.3 merc
    Gallery Images: 3
    Send Tlolesen:
    Default Re: Water in engine oil
    I had the same motor in a 2001 and a couple years ago I had same problem it was the water jacket in the port side exhaust manifold was cracked. Replaced both sides just to be sure.
    Lewy likes this.
    4.3 , gasket , mercruiser , oil , water in oil
    What water temp does your engine run at? Jeff Barnett Mercury MerCruiser 15 05-13-2018 01:46 AM
    4.3 LX Water in oil jb57 Mercury MerCruiser 19 09-23-2013 12:35 AM
    First Water Run!! truckingeorgia79 Original Mariah Talk 9 02-20-2012 08:07 PM
    how much water do you take on? bpfirrman General Maintenance 7 04-29-2008 09:35 PM
    Total Members: 18,510
    Total Threads: 12,950
    There are 387 users
