1993 2350Z prop and outdrive
General Maintenance
Old 11-21-2008, 01:30 PM   #1
cleah is currently offline
Send cleah:
Default 1993 2350Z prop and outdrive
1993 2350Z with Mercruiser 454 and alpha 1. I bought the boat a few months ago and am working through the problems. I now have it running well and we have had five excellent trips with it before I winterized. I have two questions.
1. The prop is well dinged. I trimmmed off some of the damage carefully with an anglegrinder and checked it still ran balanced. I do need a new prop. I am new to this game and this is my first boat. From what I have read and heard so far, I think I am looking for a 15" diameter, 19" pitch, four or five bladed stainless steel mercruiser prop. Is this correct?
2. I need to change the drive oil. The bushes in the hydraulic rams that steer and trim the outdrive are well worn and a bit crumbly at the surface, so I am thinking this is a good time to take the drive off, lubricate all the necessary joints, replace all the bushes, and fit new drive oil. I have done car engines and suspension, but never worked on boats (except recent water pump, etc). How big and complicated is this job? Do you have any good suggestions as to how to go about it please?
Many thanks
Clive
  • Old 11-21-2008, 05:15 PM   #2
    lomitabob's Avatar
    lomitabob is currently offline
    My Model: 2001 Z250 Shabah 7.4LMPI Bravo I
    Gallery Images: 12
    Send lomitabob:
    I also have a stainless prop and find it is more reasonable to send it out to a good prop shop for repair and polish. The shop can computer analyze the shape of the blades to optimize performance and it usually costs about half of a new one. If you don't have a spare I would suggest buying another one and keeping the old one onboard along with a hub and nut just in case you break a blade.
    Old 11-21-2008, 10:08 PM   #3
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    1. If you know the specs on your boat you might want to look at Mercury's prop selector It'll give you a bunch of size and # of blade options to suit the performance type you are looking for.
    2. Just replace the trim bushings when you pull the drive. Removing the drive is not that difficult, but it is heavy. You'll want someone to help you lift it free. Lube all the joints and have a look at the gimbal bearing in the transom. If you don't know the history on the water pump, you might also consider doing it as well.
    If you become a contributing member to the forum you have access to all the merc service manuals. There are also plenty of how-to's out there on the net.
    My Mariah
    My Shabah is using what the hybrids are saving!
    Request Prop Help - 1993 Barchetta W/ 4.3 L Lx (18+' Bowrider) Polhemus Prop Talk 5 09-06-2008 12:21 PM
    Refinishing the Outdrive bdbyrnes Projects 2 04-16-2008 05:43 PM
    Vibration from Outdrive? dudders Mercury MerCruiser 10 01-13-2008 04:09 AM
    Poss outdrive problem?? Jeff Barnett Original Mariah Talk 6 09-27-2007 10:02 AM
    Outdrive Play? Jeff Barnett Mercury MerCruiser 2 09-19-2007 07:34 PM
    Total Members: 18,994
    Total Threads: 13,325
    There are 392 users
