Engine compartment walls
3 Attachment(s)
Ok first off sorry for the long absence. I have been busy towards the end of the boating season.
I built this... it was sorta boating related :) So back to boating where I left off... the new to me 2004 5.0 SX19. Was reupholstered on the cheap and the stitching is bad and whoever did it also took out the engine compartment dividers. I was going to replace them in the off season but it might be a next year project. Does anyone have a SX19? Can you get me pictures and/or measurements? I was going to make it out of that cutting board synthetic marine grade material: 1 2" White or Black King Starboard Cut to Your Size | eBay Thoughts? |
Re: Engine compartment walls
You will like the kings board. I have used it. Cuts like wood. Sturdy and not affected by water. Only con I can come up with is its weight. There is a kings board light that is as strong but a lot less weight. Food for thought.
Ok thanks! I haven't gotten around to it yet.... Hoping to do some work on it prior to the season. Anyone got engine compartment pictures of a sx19?
I also need to find some method of supporting the rim of the sundeck. Right where the cushion rests on the fiberglass. I was thinking stainless steel support tubes like the windshield uses only larger
| All times are GMT. The time now is 06:08 PM. |
