Bilge Pump
On my 2007 SC23 when the batteries were turned on the auto Bilge Pump would start & pumpout any water under the engine
Now this pump has failed-but it seems to be located right under the engine & seems to be impossible to get to? Does anyone know where exactly it is located? Also does the BILGE switch on the dash control the same pump? If i want to replace witha new pump-how can i wire it to existing dash switch? Thanks |
Re: Bilge Pump
You might want to have a look at this thread
Re: Bilge Pump
Replaced my bilge pump with a Rule automatic. When I connect the wires, brown to brown, brown/white to brown/white and black to black, the pump runs continually. Can't figure it out, could it be a bad rocker switch?
| All times are GMT. The time now is 01:04 PM. |
