2006 SX18 In Hull Transducer Location
Sea Fox - Mariah Talk
Old 09-22-2022, 05:49 PM   #1
pevaniak is currently offline
My Year: 2006
My Model: SX18
My Engine: Mercruiser 4.3
Send pevaniak:
Thumbs down 2006 SX18 In Hull Transducer Location
Does anybody have the idea location for an in hull transducer on a 2006 SX18. i have played with different locations and am not getting good reading. the manuf. (Airmar) keeps telling me it is the location. Either hull thickness or not clean water under the boat while it is moving. Any thoughts.
  • Old 09-22-2022, 07:25 PM   #2
    Default Re: 2006 SX18 In Hull Transducer Location
    Some members who have installed an in-hull transducer have had to shave the thickness of the hull where the transducer mounts and once the transducer in place, fill the void with epoxy. The transducer is normally mounted just in front of the engine.
    Old 09-24-2022, 12:48 PM   #3
    My Year: 2006
    My Model: SX18
    Send pevaniak:
    Thanks for the reply. Do you know the thickness of the hull at that point. In other words I do not want to shave to much off.
    I would think an angle grinder would do the trick but I do not want to compromise the hulls integrity. I though an in hull transducer was the better way to go instead of a transom mount so I didn’t have to drill any holes, I am rethinking that.
    Thanks for the help.
    Old 09-24-2022, 01:02 PM   #4
    Unfortunately I dont know the hull thickness of the Sea-Fox built boats but there is probably enough to take out a 1/4" or so. What i can suggest, if you haven't already done so, is to join both of the Mariah Owners Groups on Facebook and pose the same question there. Those groups are a lot more active than this forum and there are a good number of owners who have done similar modifications.
    Old 09-24-2022, 11:13 PM   #5
    My Year: 2006
    My Model: SX18
    Send pevaniak:
    I will do that thanks
    depth finder , in hull , transponder
    transducer location gzfqy6 Introductions 1 08-25-2018 09:47 PM
    Looking at 2006 SX18 marcf Sea Fox - Mariah Talk 1 03-30-2015 08:25 PM
    Transom Mount vs. Shoot Through Hull Transducer dwymer64 Sea Fox - Mariah Talk 11 03-23-2015 06:20 PM
    2006 sx18 kevvy1210 Sea Fox - Mariah Talk 1 02-19-2014 04:56 PM
    Thru Hull Transducer 300sflyer Original Mariah Talk 4 09-28-2010 02:20 PM
    Total Members: 18,524
    Total Threads: 12,958
    There are 141 users
