Strange drain holes
Hi, and happy Friday! Im the lucky owner of a Mariah SC 25 2007 model, and I've been starting to hear some noises from these drain holes in the back of the U-saloon in the back.
Behind the cover, there is a floating ball which seems to float. When there's a lot of water in the boat, I'm not even able to shove any water down in it since it seems full. Any thoughs on what this is?https://uploads.tapatalk-cdn.com/201...883287c4d7.jpghttps://uploads.tapatalk-cdn.com/201...0e032efff9.jpg Sent fra min CLT-L29 via Tapatalk |
Re: Strange drain holes
Looks like a drain hole.... take the cover off, run something thru it to ensure that it isn't blocked. Check to make sure your outdrive bellows isn't split or cracked and leaking water into the bilge.
Don't think any water is seeping in there. Then I would have seen it in the back of the boat. Sent fra min CLT-L29 via Tapatalk |
The ball probably acts like a float to stop water from coming back up thru the drain. Sea Fox did some strange things with their version of the Mariah boat...
| All times are GMT. The time now is 09:53 AM. |
