-   Sea Fox - Mariah Talk (http://www.mariahownersclub.com/forum/sea-fox-mariah-talk/)
-   -   cockpit drain ports, 2009 R20.9 (http://www.mariahownersclub.com/forum/sea-fox-mariah-talk/10721-cockpit-drain-ports-2009-r20-9-a.html)
ssva 04-28-2016 02:25 PM
1 Attachment(s)
anyone know where to purchase the drains ports located in the recessed area of the cockpit area (see photo). mine have deteriorated/crumbling t due to UV. for reference the diameter of the drain is about 5/8 inch at the surface. these ports are made of plastic/pvc and connect to flexible hose below the dash. the hose discharges toward the side of the boat, then drains to bilge.
thanks.
ShabahZ280 04-29-2016 12:58 PM
Re: cockpit drain ports, 2009 R20.9
I believe what you're looking for are called "impact drains" based on your photo and description. They're available from a company called Marine East.
https://www.marineeast.com/a_sch/sch...d=02&pid=02_10
ssva 04-29-2016 05:24 PM
appreciate the response. I'll check it out.
thanks again.
