25 SC Tachometer problems
Sea Fox - Mariah Talk
Old 08-17-2015, 08:16 AM   #1
garejoha's Avatar
garejoha is currently offline
My Year: 2008
My Model: 25 sc
My Engine: Mercruiser 350 mag mpi
Gallery Images: 1
Send garejoha:
Default 25 SC Tachometer problems
I have a problem with my tachometer, it suddenly shows 1000 rpm to much. at top speed it goes up to 6100 rpm. ( usually 5100-5200 rpm)
The motor is running fine, this proplem comes and goes. suddenly it can dropp to normal when driving.
The motor and boat is a 2008-model with Fariamade instruments.
  • Old 08-17-2015, 08:01 PM   #2
    Default Re: 25 SC Tachometer problems
    This question gets asked quite often... check the wiring connections to ensure they are clean. Then access the back-side of the tach where you will see a small wheel marked 2-4-6-8. Give the wheel a spin a few times then reset it to 8. If that fails then it's time to return the tach to Faria since they have a lifetime warranty.
    Old 08-18-2015, 06:43 AM   #3
    garejoha's Avatar
    My Year: 2008
    My Model: 25 sc
    Gallery Images: 1
    Send garejoha:
    Thanks, I gave the wheel a spin and set i at the same place.. now the tach works great
    Old 12-03-2019, 02:49 AM   #4
    cew388 is currently offline
    My Model: Talari
    My Engine: 7.4
    Send cew388:
    I have a 2000 25 foot(don’t know model, just bought it) & tach & compass don’t work. Any ideas? Thanks
    Old 12-03-2019, 06:56 PM   #5
    Read post# 2. And if you have a "2000 25 foot" boat.... you do not have an SC25. Your boat info says you have a "Talari' and yet your other post indicates you have a Z252. If might help if you knew what boat you actually have...
    Old 02-29-2020, 10:30 PM   #6
    My Model: Talari
    My Engine: 7.4
    Send cew388:
    Can anyone tell the horsepower 2000 merc engine OL621170? Engine model is Mers 7.4L MPI Bill. Thanks
    c
    How do I remove the old tachometer? RodneyWest Original Mariah Talk 8 08-27-2020 03:12 AM
    Wanted: Need a tachometer Golfnutk2 Mariah Parts For Sale & Wanted 3 06-21-2014 10:17 AM
    Tachometer not working beau1175 General Maintenance 3 05-07-2014 08:29 PM
    Inoperable tachometer Lucky14 Sea Fox - Mariah Talk 1 09-01-2013 11:24 PM
    For Sale: Looking to BUY Tachometer themacs40 Mariah Parts For Sale & Wanted 5 04-28-2010 04:54 AM
    Total Members: 18,520
    Total Threads: 12,955
    There are 114 users
