-   -   Wanted: Dashboard Repair (http://www.mariahownersclub.com/forum/mariah-parts-sale-wanted/621-dashboard-repair.html)
pblouin 01-21-2008 03:03 PM
Dashboard Repair
All my gauges have come loose - the bolts to the back of the panel have become unglued. I need suggestions for fix. Any help? My boat is a Z272.
WetWilly 01-21-2008 04:10 PM
Hello pblouin,
What I would suggest is a bit laborious but I believe it will give you the best results...
• Remove your dash
• Remove all the gauges from the dash
• Clean the bolts and the areas where the bolts mount with a good cleaner like acetone (Careful not to get any cleaner on the front side of your dash).
• Use an epoxy such as Marine Tex Flex Set Epoxy (it’s a flexible epoxy that stands up to vibrations and movement associated to boats better that a ridge epoxy could) and follow their directions and re-glue the bolts back on.
• When it’s all dry, reassemble the dash, test gauges and go out and enjoy.
If you can't find Marine Tex Flex locally, BoatersWorld.com carries it for $16.99, here’s the link:
http://www.google.com/url?q=http://www.boatersworld.com/p/%3Flocation%3DGGSPRD%26tmreturn%3Dtrue%26utm_sourc e%3Dgoogle%26utm_medium%3Dproductsearch%26prp%3D37 7940069&sa=X&oi=product_result&resnum=1&ct=result& cd=1&cad=AIOQsCFBc6uzvjuxRdBMV0Vs1NE8xwqbq9J0EWt-Tl4uAAAAAAAAAAA&usg=AFQjCNEjozETU6ZQjC9l6Ymqpej6rI zuew
After this, you shouldn’t have any problems with loose gauges.
Good luck,
ShabahZ280 01-21-2008 05:21 PM
Believe me, this is a big deal. I'm going through repairing mine now. I will share my experiences when it's finished, but it's been probably the worst project I've ever done.
But, my dash is completely different from yours. My dash uses injection molded plastic, which is incredibly thin and brittle. I would suggest the Marine-Tex method. It has proven itself to be a great product for all sorts of boating needs. If you have the capability to take some digital pics, please share them and we'll try and walk you through the whole project!
Keep us updated!
garyg 12-22-2009 03:59 PM
Re: Dashboard Repair
Hi Plouin I have a 2000 Z 272 open bow. Did yoy have much trouble taking your dash out or is there a way to get at the back of the gages. I want get at my tack and help would be great. Gary G
Lloyd Chip Lambert 12-24-2010 03:19 PM
Re:1999 Z252 Dashboard Removal
I need to remove the tach and speedo for repair. Does anyone have any advice on removing the dashboard. I have started with kick panel/Extinguisher box, windshield support and the nuts on the back of the steering wheel (under the dash). Is this as BIG a job as it seems....or am I doing something wrong?!?!
mikeyt 12-25-2010 04:20 AM
Shabah Z250 did a "How To" on this job. You can check it out here.
