WANTED ! 4.3 Vortec marine engine
Requests
Old 07-29-2010, 04:21 AM   #1
L&K's Z 190 Shabah is currently offline
My Model: Z 190 Shabah
My Engine: 4.3 Alpha One
Exclamation WANTED ! 4.3 Vortec marine engine
Looking for late model 4.3 Vortec motor for my Mariah
  • Old 07-29-2010, 10:00 PM   #2
    Status: Super Moderator
    My Engine: 4.3LX, Alpha 1
    Gallery Images: 23
    Default Re: WANTED ! 4.3 Vortec marine engine
    Here's a little extra info on the 4.3 history as borrowed from Crowley Marine's website so that you dont end up with an older one that needed.
    Identification Tips for MerCruiser 4.3L Longblocks
    1986 - 1992, 14149R5
    Non-balance shaft, mechanical fuel pump, roller camshaft, one piece rear seal.
    A. Easily identified by metal 10 bolt short front cover similar to 5.7L.
    B. Some nQn-balance shaft engines were produced without a manual fuel pump. This engine will fit either application with a fuel pump cover if manual fuel pump is not needed. C. All 12 intake manifold bolts are at 90 degree angle to cylinder head machined surface.
    1993-1995 806347R5
    Balance shaft, no mechanical fuel pump, roller camshaft one piece rear seal.
    A. Easily identified by tall metal 10 bolt front cover different from 5.7L.
    B. All 12 intake manifold bolts are at 90 degree angle to cylinder head machined surface.
    1996- 1998 807736R5
    Balance shaft, no mechanical fuel pump, roller camshaft, one piece rear seal, "Vortech" cylinder heads with rocker ball & stud valve train.
    Note:
    A. Vortech heads are easily identified by only 2 bolts per corner of intake manifold for a total of 8.
    B. The older crankshafts rear flange are 0.123" longer and have a small pilot bushing hole in back.
    C. Plastic 6 bolt front cover.
    1999- 2002 864256A1
    Balance shaft, no mechanical fuel pump, roller camshaft, one piece rear seal, "Vortech" cylinder heads with roller rocker arm valve train.
    B. The cylinder head actually went to the "roller rocker arm" in 2000. Mercury Remanufacturing has elected to change coverage to coincide with the 1998/1999 crankshaft change as the customer would have to change flywheels to coincide with the crankshaft used. The 1999 customers will actually get a product improvement with the roller rocker arms and will not have to make any changes to their current parts.
    C. The crankshaft has a 0.123" shorter rear flange and larger pilot bushing than previous versions.
    D. Plastic 6 bolt front cover.
    mikey
    L&K's Z 190 Shabah (07-31-2010)
    Old 07-29-2010, 11:45 PM   #3
    DiggerDave is currently offline
    My Year: 2008
    My Model: 18 SX
    My Engine: 4.3 Mercrusier
    1998 Mercruiser 4.3L TKS New in Crate
    Stock Number: 359704
    crashedtoys.com
    current bid $525
    Bidding Ends: 8/4 01:00:00 PM CST (02:00:00 PM EST)
    located near Linn Creek, MO
    Thank you DiggerDave for this useful post!
    Old 06-03-2011, 08:27 PM   #4
    Xxchiulaterxx is currently offline
    My Model: 18' bowrider diablo
    My Engine: 4.3l Merc alpha one
    Default WANTED ! 4.3 Vortec marine engine
    I need a 4.3l Merc vortec either a complete engine or Long block or short block please let me know if anon has one. I've been looking online for them and they are very expensive.
    Wanted 22-23 Mariah Cuddy ddvezi Requests 1 03-20-2010 03:10 PM
    4.3L Vortec jetscat7 Mercury MerCruiser 9 02-12-2010 05:26 AM
    Ski Tube wanted dudders Watersports 10 01-26-2010 03:15 PM
    Wanted: Dock light duketter Requests 2 07-17-2009 02:00 PM
    WANTED: Mariah Goodies surbski Requests 4 07-06-2009 10:55 PM
    Total Members: 6,945
    Total Threads: 6,287
    There are 23 users
