z302 1999
Old 01-19-2015, 04:36 AM   #1
darbar is currently offline
My Model: z302
My Engine: 7.4l bravoIII
Send darbar:
Default z302 1999
looking for extended platform and original cover for z302 thx
  • Old 01-22-2015, 08:41 PM   #2
    Default Re: z302 1999
    Swimplatforms.com for the extended swim platform. They're usually upwards of $2k once you factor in crating and shipping costs, just as an FYI.
    For an original cover, you're likely not going to find one. If you're looking for a full length mooring cover, you're probably better off having one custom made from your local canvas shop, as most of the "semi-custom" or "universal" fit covers online won't fit correctly. If you're looking for just the bow or cockpit covers, you'll need to have them custom made as well, if you want them to fit right.
    Old 01-30-2015, 04:35 AM   #3
    Rynovw's Avatar
    Rynovw is currently offline
    My Engine: 1 man power & a PFD
    Send Rynovw:
    Default z302 1999
    We build custom swim platform for around the same money. Look at so of the old project post at some I've done.
    Only down fall is we have to have to boat to do them. Takes about 4 weeks
    looking for a new ride. other then the 1 man powered PFD i currently have
    Old 02-06-2015, 04:19 PM   #4
    moboaters's Avatar
    moboaters is currently offline
    My Model: Z302
    My Engine: 7.4 Bravo lll
    Send moboaters:
    We are getting ready to order a new swim platform from swim platforms.com they are a little higher than the other platforms out there but they have a mold custom fit just for the Z302 that gives the platform a factory look. Here is the information we got from them this week... Rember Shipping may be different... Hope This Helps!!
    Thank you for your time and interest in our Swim Platforms.
    Our Mariah Z 300 & Z 302 Swim Platform was designed specifically for this hull. We have invested in
    building a mold to produce a truly custom Swim Platform designed to fit the Mariah Z 300 & Z 302. No
    shaping is involved. We have attached pictures of our Mariah Z 300 & Z 302. We hope you’ll agree
    that this complements the boat and makes a great addition. You won’t find a better Swim Platform
    anywhere!!!
    The safety factor alone makes an extended Swim Platform a “must have” on your list.
    Standard Features:
    Our Mariah Z 300 & Z 302 Swim Platform measures 86” wide x 29 ½” deep of usable surface.
    The platform is constructed of fiberglass with a gel coat finish similar to your boat’s construction. For
    safety, the top surface has a diamond pattern non-skid in the gel coat. It offers a good “grip” and is easy
    to clean. A heavy rubber molding trims the bottom edge for an attractive look, as well as helping to ease
    those boating “bumps”. The platform is tapered inward at the aft corners to allow for easy maneuvering
    around docking areas, pylons and other boats.
    This platform comes with an under mount telescoping 4 step stainless steel ladder. The simple
    one handed operation makes the ladder a breeze to use and stow. Our under mount ladder allows
    the top surface to be clean and free of obstacles, complementing the boat’s clean design.
    The steps are extra wide, measuring 2 ¼”. In addition, the bottom step is 45” from the top of the
    platform making boarding the platform an ease. You’ll be spoiled by this “two tube” wide, 4 step
    design (looks like the as the 3 step ladder pictured, see attached pictures).
    Your old ladder can be removed.
    We install a large oval port in the platform allowing air and water pressure to transfer through.
    The oval port can also be used as a grab handle while one is using the boarding ladder.
    This eliminates the need for a grab handle which is a possible tripping hazard.
    We supply 2 stainless steel down rod supports for the aft end of the platform to give it added
    stability. The underside of the platform has an easy to clean gel coated surface.
    You can fit three or four people on the platform; we say 600 pounds…very conservatively.
    This addition makes boarding, BBQ’ing and all around boating nicer and much safer!
    We are confident our Swim Platforms are the most structurally sound in the industry.
    By overloading the stern (back) area of any boat you could compromise the engine’s
    exhaust system.
    Weight:
    The platform weight is approximately 130 pounds.
    Shipping weight is about 350 pounds, due to the crate and packing materials.
    You will need to be able to offload it from the truck when the platform arrives.
    Installation:
    We provide stainless steel mounting hardware and installation guidelines. Two people can usually
    complete the installation in less than half a day. You’ll need to supply a tube of caulking; we recommend
    using 3M 4200 “fast cure” if launching the next day.
    Seventy percent of our platforms are owner installed while other customers may use a local
    dealer, marina, boat yard or handy person.
    Warranty:
    We offer a one-year warranty for workmanship and materials.
    Should you ever have a concern, please let us know. As an exclusive Swim Platform fabrication company
    since 2001, we are extremely proud of our track record.
    Our staff’s tenure nets over 175 years (that’s not a typo) of experience in the marine industry and
    they are ready to build your new Swim Platform.
    Pricing:
    Our Mariah Z 300 & Z 302 Swim Platform package is $1795.00.
    This includes all stainless steel mounting hardware, 4 step ladder, oval port, rubber molding and
    Gel coat colors outside of shades of white (red, yellow, blue, black etc.), are an additional $200.00.
    For a two-tone platform please add $250.00 to the package price.
    Shipping Quote:
    (This is a separate quote from the platform package pricing.)
    Wood shipping crate and packing materials total $98.00.
    The current freight (FOB Phoenix, AZ) to a commercial address at zip code 63129 is $213.00. (OD*)
    You will need to be able to off load it from the truck.
    A delivery charge to a residential address is an additional $63.00.
    We do not apply sales tax for out-of-state delivery.
    1999 z302 Motoxxx43 Mariah Boats For Sale & Wanted 6 12-11-2012 04:47 PM
    1999 z302 for sale tobaccogrower Mariah Boats For Sale & Wanted 2 12-04-2009 07:11 PM
    1999 Z302 with 502Mag, $34k/obo ShabahZ280 Mariah Boats For Sale & Wanted 5 10-14-2008 08:17 PM
    1999 Z302 questions grandlake mariah z302 Original Mariah Talk 8 04-22-2008 04:02 PM
    1999 Z302 Boatcrazy Introductions 17 09-08-2007 06:14 PM
    Total Members: 18,520
    Total Threads: 12,955
    There are 257 users
