ignition switch 2000 z244
Old 10-20-2014, 12:05 AM   #1
ourmariah is currently offline
Send ourmariah:
Default ignition switch 2000 z244
Looking for a complete ignition switch for a 2000 z244, any suggestions at all will be greatly appreciated.
Thanx
Also need wiring diagram for ignition if anybody has that available.
Thanx again
  • Old 10-20-2014, 12:50 AM   #2
    My Model: Z258
    My Engine: 7.4 & Bravo 3
    Send 99 Mariah 258:
    Default Re: ignition switch 2000 z244
    Thanx
    Thanx again
    Hello...... I also need to replace my ignition switch as I just changed my starter,wiring leads and cleaned all my battery connections and grounds and my boat still won't fire up ....Pulled the ignition switch out and the boat finally turned over.... Now it starts sometimes on the first try but at other times won't turn over until 3-4 turns of the key ( won't click or make any noise at the starter) ........ My question is will any generic 4 position ignition switch work for me..... I'm really trying to get this fixed tomorrow and can't wait to order a original switch and key.... Thanks in advance.
    Old 10-20-2014, 02:56 AM   #3
    New original equipment ignition switches and matching Mariah keys are still available from one of our members. Check out our Original Parts & Vendors list. or this post by the vendor.
    Old 06-10-2016, 03:22 PM   #4
    dbrim is currently offline
    My Model: 180 SHABAH SE
    My Engine: 4.3L ALPHA 1
    Send dbrim:
    Mariah Ignition switch
    4 position
    Accessory – Off – On – Start
    Sierra MP41040
    Try Gander Mtn for $14.99
    Yellow with red stripe - (S) (starter Solenoid)
    Purple - (I) (ignition)
    Small Red and Purple (two wires) - (A) (Accessory)
    Big Red - (B) (battery)
    Old 06-11-2016, 03:27 PM   #5
    My Model: Z258
    Send 99 Mariah 258:
    Thumbs down Re: ignition switch 2000 z244
    My 99 7.4 Mpi had very similar symptoms. I changenged everything and somethings twice. 3 things that finally worked was 1. Replaced the ground connector that attaches to the back of the block 2. Had a mercruiser quicksilver starter installed by a "certified" tech but when I checked the bolts were loose and the last thing was the 20 amp breaker for the ignition ...the one under the dash.
    2000 z244 ignition switch problem ourmariah Original Mariah Talk 2 10-16-2014 04:25 PM
    Ignition Switch blatt88 General Maintenance 0 09-27-2014 01:38 AM
    Ignition Key Switch? Chickman Original Mariah Talk 4 04-29-2014 06:15 PM
    2000 Z244 Jubilee for sale dpriebe Mariah Boats For Sale & Wanted 0 08-31-2013 11:33 PM
    2000 Z244 Fuel Tank Capacity? NoelinGV Introductions 2 07-31-2010 05:56 AM
    Total Members: 18,525
    Total Threads: 12,958
    There are 244 users
