Electrical Wire Diagram (99 Jubilee) 214
Old 04-10-2008, 10:01 PM   #1
Gallery Images: 2
Send Douglas Alderman:
Default Electrical Wire Diagram (99 Jubilee) 214
My boat has electrical problems. All battery power is on all the time. Even when power switch is turned off. Need a wire diagram for my boat. Probably start looking for problem at power, on and off switch first for corrosion.
  • Old 04-12-2008, 06:02 PM   #2
    202
    202 is currently offline
    My Model: 2000 202shabah 5.0efi bravo III
    Send 202:
    i have a page that tells you what each wire is for a 2000 20' -24'electrical system:deckboats. if this would help i will fax to you.
    Old 04-13-2008, 03:20 AM   #3
    We have the wiring diagram in the contributors section! Click in the Manuals & Supplements section, and then search for Mariah Wiring Harness Diagrams, then you can downloade specifically the 2000 model!
    Old 04-13-2008, 05:22 AM   #4
    Gallery Images: 2
    Default Wire Diagram
    Thanks for the Post! The Mariah Boats seem to have the same color code. Making it easy to trace the electrical system. I have full power at the dash. Navigation and ancor lights not working. Key will turn off acc. and radio only. All switches have power. Battery knob switch won't turn off power.
    Wiring Diagram bakdraft Sea Fox - Mariah Talk 17 06-26-2009 01:56 AM
    Marine ACDC electrical site mikeyt General Maintenance 0 03-05-2008 12:37 AM
    electrical problem nickc Sea Fox - Mariah Talk 4 02-24-2008 06:34 PM
    Electrical Fix Straad General Maintenance 2 08-28-2007 12:26 AM
    Total Members: 18,510
    Total Threads: 12,950
    There are 202 users
