Bravo 3 prop swap questions
Prop Talk
Old 08-19-2014, 12:11 PM   #11
Hudson River Steve's Avatar
My Model: Z280
My Engine: 7.4L MPI Bravo3
Send Hudson River Steve:
Default Re: Bravo 3 prop swap questions
Rates depend on your area. Like I said, I have performed this job and it was not easy to access. I would not have an issue paying a a pro to have the job done correctly.
Sent from my DROID2 using Tapatalk 2
99 Mariah 258 likes this.
Hudson River Steve
1999 Z280
7.4 MPI, Bravo3
99 Mariah 258 (08-19-2014)
  • Old 01-26-2021, 01:06 AM   #12
    globa1950 is currently offline
    My Model: z222
    My Engine: bravo 3
    Send globa1950:
    hi guys. please help. i need advice
    i have 2 propellers but i would like to remove one and to try ride the boat with one.
    is it safe? will it not harm engine itself? I have mercruiser bravo 3.
    also if i remove one propeller- will it be okey for that metal beam that is sticking out from the lower unit( propeller holder)
    Old 01-26-2021, 06:03 PM   #13
    Again, It has been answered in your initial thread.
    Old 05-05-2021, 02:24 PM   #14
    My Model: z222
    My Engine: bravo 3
    Send globa1950:
    1999 Mariah z222 Shabah
    with 502 Mag MPI getting hot and not getting enough water thru those tiny little holes in the prop.
    and because it also came with freaking bravo 3 - IT DOESNT EVEN HAVE THE IMPELLER inside there.
    can some one advice what is the best to swap bravo 3 to?... big block v8 needs muchg more water flow
    Old 05-05-2021, 02:39 PM   #15
    My Model: Z280
    Water comes from holes on either side of the outdrive, not through the prop. Make sure they are clear. The Bravo pump on the big block engines moves lmplenty of water. Check the impeller in it and make sure hose from gimbal ring to transom assy is not kinked. Lastly, check various coolers installed on engine for blockages, often caused by pieces of rubber impeller that broke off.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 05-05-2021, 03:07 PM   #16
    My Model: z222
    My Engine: bravo 3
    Send globa1950:
    yeah so correct.
    new impeller, but i will double check again all the hoses.but still the cold water hose still once disconnected before thermostat housing- it still not quite a streat id like to see while im in the water.
    plust bravo three doesnt have the impeller in the stern drive thing...
    so again - id like to know if its best to swap the bravo 3 to something that would work for my 502 mag 8.2L
    to get the fountain of water in the engine
    Old 05-05-2021, 04:20 PM   #17
    My Model: Z280
    The only drives that have water pump in the drive are the alphas which are only rated to 300hp. Your 502 would twist an Alpha up in no time. All other bravo drives use engine mounted pump just like you already have. You have an obstruction somewhere.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 05-06-2021, 11:50 AM   #18
    Global- there is nothing wrong with a bravo 3 outdrive. They are a very desirable outdrive. While a bravo 3 does NOT have an impeller in the outdrive your problem with water supply to the sea pump(on the engine block) may be in your outdtive. Not sure how mechanical you are but this is not a terrible fix. This KIT fixes the issue you might be able to address the issue with THIS and get a few seasons out of it.
    If you are certain you are not getting enough water to your sea pump the above issue would be a great place to start.
    Bravo III Prop Shaft Discoloration Humpty Prop Talk 10 07-29-2014 07:12 AM
    bravo 3 new prop shaft seals leaking Txtruckerpaul Mercury MerCruiser 15 05-05-2014 09:00 PM
    Bravo 2 prop on a alpha 1 drive? dieselwiezil Prop Talk 1 07-14-2010 08:15 AM
    bravo 3 prop question jgreen Prop Talk 5 07-29-2009 04:42 AM
    2350Z/454/bravo 1 prop selection cleah Prop Talk 3 06-03-2009 10:37 AM
    Total Members: 18,525
    Total Threads: 12,958
    There are 171 users
