1997 Talari 209
We have a 5.7 alpha drive, 2 barrel and are looking for the "right prop". Currently there is a 19" stainless which needs to be replaced. It seems great for skiing but we are looking for fuel economy without losing too much bottom end. Suggestions?
Re: 1997 Talari 209
Unfortunately there is no "right prop", only props that work best in specific applications. If you want just a little better prop for cruising & yet retain some of that low end grunt then i would suggest a 20" - 4 blade prop. The Michigan Wheel "Apollo" works quite well in that application. When you have a few minutes, read the STICKYS at the top of the Prop Talk Forum.
| All times are GMT. The time now is 09:37 AM. |
