-   -   Z222 prop pitch? (http://www.mariahownersclub.com/forum/prop-talk/8290-z222-prop-pitch.html)
Eclipse9719 06-14-2013 02:32 PM
Z222 prop pitch?
Hi everyone, I am going to pick up my Z222 next weekend.... It has a 7.4 merc. I was wondering if anyone has any good prop pitch recommendations (anyone have a Z222 that can help me out?). It currently has a 21 pitch on it now, from my past experiences that seems kinda light or undersized.
Any thoughts anyone? Any help would be greatly appreciated.
ColoradoDiablo 06-14-2013 03:03 PM
Re: Z222 prop pitch?
What is your WOT with the 21p now?
Should be in the 4200-4600 rpm range as per manual.
If it is higher you need to go up in pitch , if it's lower you need to go down in pitch.
Eclipse9719 06-14-2013 05:21 PM
I haven't had it on the water yet... I was hoping someone that had a Z222 with a 7.4 could let me know what they are running for a prop pitch.
( Or similar set up)
mikeyt 06-14-2013 08:43 PM
Why dont you run yours first and record the top speed & WOT rpm's. That way if there are any adjustments to be made we have some base data to work with.
Eclipse9719 06-16-2013 01:10 AM
Does anyone have a Z222 with a 7.4? What prop are you running?
