-   -   Prop (http://www.mariahownersclub.com/forum/prop-talk/5294-prop.html)
z71forme 03-28-2011 01:05 PM
Prop
Does anyone have any suggestion on what pitch prop I need for my Mariah 190 4.3 L. I am looking
for speed but able to get the boat down when starting off.
mikeyt 03-28-2011 03:40 PM
Re: Prop
What pitch prop is on the boat now and how does it perform? That info will help us give you a little more accurate answer. Most members here run the 3 blade 19" aluminum prop though on that combo.
z71forme 03-28-2011 06:57 PM
Re: Prop
It is a 21.
mikeyt 03-28-2011 07:55 PM
Re: Prop
ok, if its a 21" pitch & you are having difficulty getting the bow down & onto plane easily then a drop to a 19" pitch will solve that problem. Also, do a site search for 'Smart Tabs'. They do wonders for planing & stability at a cost of a little under $150. There are lots of satisfied members here who have installed them. You can also check them out here at the Nauticus site. Your boat will need the 60# actuators and they are relatively easy to install yourself.
z71forme 03-28-2011 08:04 PM
Re: Prop
Where can you purchase a resonably priced 19 prop
mikeyt 03-28-2011 08:09 PM
Re: Prop
There are lots of places to look. My preference is iboats.com. Here's the link to their 19" Prop selection for your motor/outdrive.
