Original Prop Specs? 2001 202 Shabah 5.0L
Would anyone know the prop specs for our 2001 Shabah 5.0 Merc Bravo 1?
Thanks. |
Re: Original Prop Specs? 2001 202 Shabah 5.0L
Probably 14.5"dia x 19" or 14.25 x 21" pitch depending on what the boat was mostly used for. The 19 will give a little more low/mid range grunt while the 21 will give a slightly higher top end.
Mikey
This helps a lot. At least it'll give me something to go by. Greg |
| All times are GMT. The time now is 04:18 PM. |
