Shabah 198 SE prop suggestions
Prop Talk
Old 07-22-2018, 11:57 AM   #1
Navysandsquid is currently offline
My Model: Shabah
My Engine: 5.7l alpha 1
Send Navysandsquid:
Default Shabah 198 SE prop suggestions
Hey everyone I’m new to Mariah. The 198 se 5.7 A1 I just got needs a new prop. I hate to be that guy that “asks for suggestions”. But I’ve been doing some research and there’s seems to be a lot of options and rpm requirements etc. i want the best options for knee/wake boarding. I’ve been looking at the HIGH five. It’s expensive. I was wondering if anyone else has any good experiences they would like to share or honest opinions thanks in advance
  • Old 07-22-2018, 01:50 PM   #2
    Default Re: Shabah 198 SE prop suggestions
    You could start by reading any of the 3 STICKYS located at the top of the Prop Forum as they will give you the basics to make a choice for your needs.
    What prop (pitch/ number of blades/ SS or aluminum?) is on your boat now and have you tried wakeboarding/kneeboarding with it? How did it perform?
    Spend your $$$ on a 'High 5' if you want to but there are less expensive (pitch/diameter/blades) options out there that will provide the performance you are looking for. Just off the top of my head i would think an 18 or 19 pitch - 4 blade SS prop would do the job quite nicely.
    Old 07-22-2018, 10:32 PM   #3
    My Model: Shabah
    Send Navysandsquid:
    Spend your $$$ on a 'High 5' if you want to but there are less expensive (pitch/diameter/blades) options out there that will provide the performance you are looking for. Just off the top of my head i would think an 18 pitch - 4 blade SS prop would do the job.
    I’ve read those post I was more looking for brand and where to buy from maybe some suggestions of particular props.
    Old 07-22-2018, 11:45 PM   #4
    Okay.... If 10 people respond here you will likely get 8-9 different answers because what works on one boat doesn't always work as well on another similar boat. That said, I use a Michigan Wheel Apollo SS 4 blade and it works well for me when used for wake boarding & tubing. Solas makes a decent 18 & 19 pitch 4 blade SS prop also.
    iboats.com is a good site for reviewing & choosing a prop
    Old 07-23-2018, 04:24 PM   #5
    Scottie1961's Avatar
    Scottie1961 is currently offline
    Status: Gold Contributor
    My Model: Z202 Shabah
    My Engine: 5.7L Alpha One
    Send Scottie1961:
    Mikeyt is right, you'll get a lot of opinions on recommended props and most will be good advice. You just have to find the best options for your boat. The boat probably came with a 21 pitch originally so use that as your starting point. That's a lot of engine for that boat so I wouldn't go too small. A 19 pitch is a good balance of holeshot and top speed. I use a 19 on my 202 most of the summer but in the fall I put the 21 on and enjoy the extra top end. I have a wakeboard tower and the 19 pitch seems to help control the speed and allows me to trim the motor up at slower speeds to create the "big" wake.
    Also, I don't think I've ever paid for a new prop. There's a prop rebuild place in town and I have found some sweet deals from this place. I had them redo the original prop and bought a stainless 19 pitch for $190. Might see what you can find but the places mikeyt listed are a good start too.
    1995 Mariah Z202 Shabah
    5.7 Alpha One Gen II
    Suggestions on what Batteries to buy lampeta Mercury MerCruiser 5 06-15-2017 11:13 AM
    Looking for suggestions and recommendations Jgos929 Projects 6 09-26-2011 07:52 PM
    suggestions on 5.0 alpha one prop -shabah 202 yblockmike Prop Talk 4 09-10-2011 08:53 PM
    Suggestions. tclark Introductions 0 09-06-2009 06:54 PM
    Total Members: 18,525
    Total Threads: 12,958
    There are 210 users
