94 Z220 Prop Question
Prop Talk
Old 10-06-2017, 02:45 AM   #1
juttmk is currently offline
Send juttmk:
Default 94 Z220 Prop Question
94 Z220
7.4L
Bravo 1 1.50 ratio
19 pitch Mirage Plus (No Plugs)
SX trim tabs
Corsa Captains call exhaust
28 gallon of fuel
400lb passenger weight
500lb cargo
Just installed freshly rebuilt engine back in May. Spent most of the summer properly breaking in the engine. Now that the engine is broke in I'm trying to figure out why my top speed is so low. The timing is correct and RPM's have been verified on the timing lights rpm function.
4800 rpm
1/2 trim
40 mph
One of my solenoid for the dumps went out and the boat would not even get on plane due to the cavitation that was occurring with no plugs in the props ventilation system. Could the force of water through the prop be causing the high prop slippage(35%)? What would be the best option for a prop that would give decent hole shot and top speed? Should I start with plugging off the props ventilation ports?
  • Old 10-06-2017, 03:53 AM   #2
    Scottie1961's Avatar
    Scottie1961 is currently offline
    Status: Gold Contributor
    My Model: Z202 Shabah
    My Engine: 5.7L Alpha One
    Send Scottie1961:
    Default Re: 94 Z220 Prop Question
    Take my comment with a grain of salt as my experience with those vents is on an outboard. I had a center console fishing rig and heard the vents helped the prop to spin up very quickly which is critical in shallow water starts. I don't think the vents affect the prop slip once up on plane. At least that is my understanding. I would plug the holes anyway and see if that makes a difference. Just a shot in the dark but have you checked the prop hub? Could you be getting some spin which would rob you of some power. Usually they just spin out but who knows?
    1995 Mariah Z202 Shabah
    5.7 Alpha One Gen II
    Old 10-06-2017, 11:35 AM   #3
    Send juttmk:
    Thanks for the reply!! I will pick up some plugs today and see what happens.
    Old 10-06-2017, 02:24 PM   #4
    Send juttmk:
    Pitch:19
    Ratio:1.50
    Max RPM: 5200 Timing Light Fly Wheel Verified
    Speed: 42 GPS
    Calculated Slip: 34%
    1994 Z220 Trim Question juttmk Original Mariah Talk 5 07-22-2016 02:38 AM
    Prop question agarrod Prop Talk 7 08-22-2011 01:19 PM
    Yet another prop question Mike S Prop Talk 6 06-05-2010 01:35 AM
    prop question joel84 Prop Talk 0 05-22-2010 02:01 AM
    Prop Question Kitto Prop Talk 5 02-09-2009 07:50 PM
    Total Members: 18,520
    Total Threads: 12,955
    There are 197 users
