-   Projects (http://www.mariahownersclub.com/forum/projects/)
-   -   Livewell Conversion (http://www.mariahownersclub.com/forum/projects/6876-livewell-conversion.html)
ColoradoDiablo 05-28-2012 04:00 AM
Livewell Conversion
I was thinking about converting the front cooler under the bow cushion on my 180 Diablo to a livewell. Just wondering if any one has done this , and if so what kinda problems did you run into?
Thanks ,
Larry
Oregondunes 05-28-2012 06:19 AM
Re: Livewell Conversion
its gonna make a mess in your boat. most live wells are in the rear where there is lil boat movement from wave action
ColoradoDiablo 05-28-2012 03:46 PM
Ranger and other manufacturers have had them in the bow for years. I understand what you are thinking , but if the lid is setup right it isn't going to leak out.
Any other thoughts?
Thanks ,
Larry
Oregondunes 05-29-2012 04:46 PM
Any other thoughts?
Thanks ,
Larry
Most of your bass boats have similar hulls that you might find on a barefoot ski boat. they are designed to ride on only the last 2 feet of the hull at full plane.
our boats wont do that and porpoise more
ColoradoDiablo 05-30-2012 03:35 PM
Well , I got to looking and I don't think it would be big enough anyway OD. So I'm thinking about in the rear under one of the seats next to the engine cover. Now I just got to decide what side!
Always something!! Decisions ....Decisions.....Decisions
Larry
Oregondunes 05-30-2012 05:11 PM
Larry
how many people do you fish when your out ? if just two others, the ballast will be opposite you.
how much water/fish weight are you thinking it will be ?
ColoradoDiablo 05-30-2012 05:18 PM
Usually just the wife and myself. I'm looking at a 14gal tank that I think will fit under the seat/sundeck good. I have already moved the battery from the starboard rear corner to the port side right under the glovebox. I have the trim pump on the port side rear and don't think I can move it much.
I'm thinking maybe an additional 150lbs.
Larry
Dredd 05-30-2012 05:53 PM
Just food for thought, some people use a bait bag for a live well. They can be easily removed when not needed.
http://mmmwebstore.com/img/med/40-0.jpg
Oregondunes 05-30-2012 08:37 PM
Larry
Whats a typical size fish you go after ?
If you do a 15 gal poly tank (20"-10"-18")
......with water and catch you should be able to stay at 150 lbs
ColoradoDiablo 05-31-2012 12:11 AM
Mostly trout , crappie , perch , bass , wipers.
I'm like you... I think I'll be fine.
I did shave about 60lbs of engine weight off of her with aluminum intake and aluminum exhaust manifolds :)
Thanks guys for the input.!
Larry
