Thru-Hull exhaust
Hello. I'm going to install Corsa captian choice exhaust to my 1996 Shabah Z 272. No sure wether I should go straight out the back transom or come out the side. The side tips look like the dock light retainers. I'm leaning toward the side outlet look. Any suggestions???
Re: Thru-Hull exhaust
If you want it to look stock, go out the back and use the rectangular/oval shaped tips.
I've heard the side exit sounds louder inside, in front, and to the side of the boat. Whereas rear exit is obviously louder behind the boat. I've also heard side exit sounds "different" due to mainly hearing only one side at a time. The side exit will also take up more room inside the storage areas. Personally, I like the rear exit and would like to have a stock look if possible. |
845paulg I have a 2000 Z 272 7.4 MPI with captains choice.If you look ai the gallery 2000 gary g's Z272 you can see what my exhaust looks like. Hope this may help you.I love the sound of the motor when you take off or when you fire the Z up at the dock and the smiles you get from other boaters .I always get many good compleiments about our boat ,most can't beleive its 10 years old. Gary G :wink_thumbup:
Im contemplating the thru hull setup (but not the captains call), and wanted to make sure it wasnt tooo loud. Not that noise doesnt bother me, its the peps around me that get annoyed at it all. |
Oregondunes That what is nice about captains choice that I just flip the switch and exhaust is normal and the wife is happy as she does like the noise as she calls it. But when I am in the boat its my choice. THERE IS NO WATER BUBBLING NOISE to answer your question. Hope this helps. If you look at my pictures in the gallery it shows good pictures of my exhaust and my trim tabs Any more questions just fire away. Gary G :wink_thumbup:
| All times are GMT. The time now is 01:08 PM. |
